Also, make sure you have the latest Z-Wave plugin update to see the three devices in the image for each switch. Without it you'll only see one device.
HomeSeer lighting is Here!
Originally posted by SeaOtter View PostI installed six of the new switches on two different controllers using the Z-Tool+ app and none of them installed the Sceen 001 key pressed device.
Is there anyway to release a firmware that would give us the option to leave the bottom LED on at all times even when the dimmer is turned off. All other dimmers on the market have this feature. That's the only thing preventing me from buying another 10 of these dimmers. Other than that, I'm extremely happy with them.
I assume this is referring to the switch, not the dimmer?
I will note for a firmware update. There won't be an update for quite a while, the certification process alone takes a long time and is expensive.
Here is a trick that might work though. The switch has a setting to swap the function of the LED. So create an event that when the switch goes ON, send the parameter command to set the LED ON when the switch is on, and when the switch goes OFF, set the parameter so the LED is ON when the switch is OFF. I am not sure if just setting the parameter will immediately affect the LED, but you can test that in the settings for the switch.
I am not aware of any Z-Wave switch that has the option to leave the LED ON at all times?
Update: I can confirm that this works, changing the parameter will immediately change the LED.
Originally posted by jumper4000 View PostIs there anyway to release a firmware that would give us the option to leave the bottom LED on at all times even when the dimmer is turned off. All other dimmers on the market have this feature. That's the only thing preventing me from buying another 10 of these dimmers. Other than that, I'm extremely happy with them.Last edited by rjh; April 22, 2016, 02:31 PM.
Originally posted by rjh View PostI will note for a firmware update. There won't be an update for quite a while, the certification process alone takes a long time and is expensive.
I see, I missed the dimmer part. Right, all the leds go off when you turn it off and there is no setting. I will make a note, if we have to update for any other reason I will see if I can get that in there.
Originally posted by jumper4000 View PostSorry, this is a HS-WD100+ Dimmer. That workaround would be great, but can I set that Parameter on the dimmer? I don't see it under Settings... What I meant was that all the other dimmers that I know of (GE, Enerwave, Lutron, Linear, etc) give you the option to leave the LED on when the dimmer is off. Yours is a little different. Yours has several LED dim level indicators that turn on when the dimmer is on (which is awesome). What I want is for the bottom LED to remain On, even when the dimmer is off.
Originally posted by rjh View PostI assume this is referring to the switch, not the dimmer?
I'm not sure about other multi-LED indicator switches (Cooper, Leviton), however.
Originally posted by macromark View PostI don't think that's true... that dimmers have an "always on" setting. This is what is normally available for dimmers with a single LED indicator:
Originally posted by macromark View PostPost your support profile so we can see which version of the software and plug-ins you have installed.
Z-Wave 3.0.1.66
Is there a formal display of a support profile?
I just updated the Z-Wave plugin software and rebooted the ZEE S2 and only see the on/off toggle of the root device. If I go to the z-wave tab for the device I can set the "switch reverse", "LED Mode", and response to "all on, all off commands" thats all that is there.
Originally posted by jumper4000 View PostUsually even when HomeSeer doesn't know about the parameter in Settings, if you look at the device manual, it'll tell you what Parameters to set in order to change the LED behavior. For example, HomeSeer doesn't automatically give me the option to change the LED behavior on my GE dimmers, however if you look at the manual it'll tell you that if you change Parameter 3 to 0, 1, or 2, it will change the LED behavior. See page 20 here - http://www.lowes.com/pdf/irisMicrosi...mer_Switch.pdf. I was hoping for something similar on these new HomeSeer dimmers, but so far haven't found anything and according to Rich, it may not be possible.
LED
When shipped from the factory, the LED is set to turn ON when
the connected light is turned OFF. This is the default setting and
can be changed if your primary controller supports the node
configuration function. To make the LED turn ON when the light is
turned ON, change parameter 3’s value to “1”. To turn the LED OFF
at all times, change parameter 3’s value to 2.
• Parameter No: 3
• Length: 1 Byte
• Valid Values = 0, 1 or 2 (default 0)
This is consistent with the screen shot I included above and with what I said. There's no option that keeps the LED on at all times. However, there is an option that keeps it off at all times.
Originally posted by macromark View Poston at all times. However, there is an option that keeps it off at all times.
