Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Help
HomeSeer Help Help, How-to's and Documentation
Old November 10th, 2017, 11:49 PM
huggy591's Avatar
huggy591 huggy591 is offline
Seer Master
Ninja Pan/Tilt Support?
I've got HS2 and HS3PRO here running on Windows systems (I've been slowly trying to move over to HS3, but I have a lot of OLD X10 gear and HA stuff like Audreys, etc.). Now, I'm not able to use a lot of them as I migrate, but I would like to press some old Ninja Pan/Tilt bases into service on at least one of those HS platforms.
Does anyone support the use of these interfacing with either HS2 or HS3 now? I'd like to be able to control them through HS. Many of the old scripts and plugins have all dried up, at least online. I do have the various interfaces, but have not been able to get them integrated with HS2 or 3.
Open to suggestions. Maybe inexpensive Pan/Tilt bases that do work with HS3?
Old November 12th, 2017, 05:09 PM
Pete's Avatar
Pete Pete is offline
OverSeer
You can utilize Homeseer 3 with Python and there is Python configuration for use with the Ninja pan/tilt bases here ==>
X10 CM19A Python driver
or
purchase the PT Foscams sold by Homeseer.
Automator
HS3 Pro & Lite Edition Beta 3.0.0.435
Old November 28th, 2017, 12:58 AM
huggy591's Avatar
Seer Master
Thanks Pete, I've got the python script working. Now I just have to tie it to HS3. I'll look for scripts for that.
Old November 29th, 2017, 08:37 AM
Pete's Avatar
OverSeer
You can call a python script in Windows. I have never done this. Just give it a try. You will not break HS3 doing this. Looking at the old XTCR14A it appears to be using only four X10 codes.
I am sure you may be able to replicate this using the Homeseer 3 RFXCom (with a W800-RFX RFX Com RX/TX device) plugin?
What radio device are you using to talk to the Ninja devices?
Just sniff the wireless commands with the plugin and replicate them with Homeseer 3 commands maybe?
Tags
ninja
HTML code is On
Ninja Spheres Jakob.Sand HomeSeer General Discussion Area 0 March 30th, 2015 06:28 PM
CM 15 & Ninja ? kruane Lighting & Primary Technology Discussion 3 March 20th, 2012 02:38 PM
Has anybody mounted a different camera on the ninja pan/tilt base? kevind HomeSeer General Discussion Area 2 December 20th, 2005 11:47 AM
X10 Ninja Pan Tilt Applet Web Server and Interface 2 July 16th, 2002 10:00 PM
X10 Ninja Pan Tilt Applet Web Server and Interface 0 January 1st, 1970 12:00 AM
