Yes I expect that can be added. I will be unable to use the + as this is already used in the command string for something else. Maybe the ^ character.
Jon00 Philips Hue Wi-Fi Lamp Controller for Homeseer 3 & Homeseer 4
Originally posted by jon00 View PostV1.0.5 is now available.
This version allows you to increase or decrease the brightness for a single lamp.
BTW, in the mean time I was able to 'brighten' a lamp using the following code
H2 = Hue lamp 2
&hs.SaveVar "Jon00PH","(2,0,1," & round((hs.devicevalue(H2)+10)*2.54) & ",,,5,,,,)"
It takes the current brightness percentage (device value), adds 10 to it and multiplies it to match the appropriate range (brightness between 0-255)
(brain hurts )
PS. I have created an Excel Sheet that allows you to create events, actions, etc. really easy and copy/paste the complex command/result into homeseer.
Will post this in the next week or so.
excel would be nice
H2 = Hue lamp 2
(brain hurts )
Will post this in the next week or so.Best,
Jakob Sand, I automate everything!
Having trouble getting plugin to start
Hey Jon,
I believe I've followed the instructions but for some reason when try and execute the plugin from the start folder is returns an error the the plugin has stopped working and then fails. I can't seem to get past this point.
Any ideas why this might be?
Greg
here's the log file:
4/6/2013 12:48:05 PM - Jon00_PhilipsHue - Starting plugin...
4/6/2013 12:48:05 PM - Jon00_PhilipsHue - Connected (192.168.1.150)
4/6/2013 12:48:05 PM - Jon00_PhilipsHue - Version: 1.0.5
4/6/2013 12:48:05 PM - Jon00_PhilipsHue - Warning: Your ZigBee IP bridge has not been registered with Homeseer - see documentation
4/6/2013 12:48:05 PM - Jon00_PhilipsHue - Warning: No lamps detected!
Hey Jon,
Got the plugin working but for the life of me I can't get a script to run. I have to confess I've never scripted anything before so I read up on making a simple script to turn a light off. Got that working but when I start pasting some of the syntax you all have posted here I start to run into trouble.
Here's the syntax I'm using to try and set the light to 3000k:
Sub Main ()
&If hs.DeviceStatus("L02")<>3 then
hs.SaveVar "Jon00PH","(1,0,0)" else
hs.SaveVar "Jon00PH","(1,0,1,255,,,,3000)"
end if
End Sub
My Hue Light is set to device ID L02.
The log files shows this when I try and run the script:
4/6/2013 3:48:29 PM - Event - Event Trigger "light test"
4/6/2013 3:48:29 PM - Event - Running script in background: lightoff.vbs
4/6/2013 3:48:29 PM - Error - Running script, script run or compile error in file: lightoff.vbs1042:Must be first statement on the line in line 3 More info: Must be first statement on the line
Since I really haven't done this before I really don't understand what the problem is as the log file doesn't really tell me exactly what's wrong. It seems no matter what code I drop in from the examples here I always get an error message similar to this one.
Any help would be appreciated!
Thanks again
Greg
