I'm sorry - I know this is probably not in the right place... Rob Mason has/had a plug-in for the HAI system that is/was in beta... it used to have a support forum, but the link is now dead and I could not find the sub-forum on the board here. Hence my posting this here.
My question - and this could apply to the plug-in itself or just be viewed as a general question - is:
Can anyone suggest a way to translate flags or other status from the HAI OmniProII panel into something usable by HS3? I need triggers to hand-off functions between the HAI system and HS3 - basically so that if they can't bidirectionally "talk to each other", at least I can pass status messages, flag conditions, or similar uni-directionally from the HAI to the HS3 so that HS3 can enact the various and many things not possible from within the HAI panel.
In simplest terms my primary objective is to pass some sort of variable (flags?) to HS3 so that HS3 can playback voice files. I'm sure there are other things.
Right now, even in beta form, Rob Mason's plug-in DOES pass the status of security zones from HAI to HS3, but I need some sort of virtual device for doing things beyond simply, "Is Zone X on or off?"
Sorry for the long post!
Thanks for any advice,
Jcd
Jcd
