A new beta 1.0.6.10 has been send to the updater. View the first post for the changes.
Wim
Wim
dec-17 17:04:18 JowiHue Plugin succesfully started dec-17 17:04:18 JowiHue ============================================================================================== dec-17 17:04:18 JowiHue Device of reporting bridge and light firmware updates is enabled dec-17 17:04:18 JowiHue 6 Animations available for use in this plugin dec-17 17:04:18 JowiHue 25 Local scenes available for use in the JowiHue plugin dec-17 17:04:18 JowiHue -------------------------------------Plugin info --------------------------------------------- dec-17 17:04:18 JowiHue 2 Generic flag sensor found on bridge 'Philips hue' dec-17 17:04:18 JowiHue 1 Daylight sensor found on bridge 'Philips hue' dec-17 17:04:18 JowiHue 1 TAP found on bridge 'Philips hue' dec-17 17:04:18 JowiHue 7 Groups available on bridge 'Philips hue' dec-17 17:04:18 JowiHue 15 lights connected to bridge 'Philips hue' dec-17 17:04:18 JowiHue -------------------------------------Bridge info --------------------------------------------- dec-17 17:04:18 JowiHue ============================================================================================== dec-17 17:04:18 JowiHue Devices added for new group Keuken dec-17 17:04:18 JowiHue Devices added for new group Serre dec-17 17:04:17 JowiHue Devices added for new group Alle Lampen Bij Weg dec-17 17:04:16 JowiHue Devices added for new group Slaapkamer dec-17 17:04:15 JowiHue Devices added for new group Berichtgeving dec-17 17:04:14 JowiHue Devices added for new group Woonkamer Lampen dec-17 17:04:13 JowiHue Devices added for new group All Lights dec-17 17:04:11 JowiHue Devices added for new light LC Slaapkamer dec-17 17:04:10 JowiHue Devices added for new light LW Logeerkamer dec-17 17:04:10 JowiHue Devices added for new light LC Gang dec-17 17:04:09 JowiHue Devices added for new light Hue Serre Bol dec-17 17:04:08 JowiHue Devices added for new light Hue Dressoir dec-17 17:04:08 JowiHue Devices added for new light Hue Staande Lamp dec-17 17:04:06 JowiHue Devices added for new light Hue Bank dec-17 17:04:05 JowiHue Devices added for new light Hue TV Rechts dec-17 17:04:04 JowiHue Devices added for new light Voordeur dec-17 17:04:03 JowiHue Devices added for new light Keuken Spot 2 dec-17 17:04:02 JowiHue Devices added for new light Keuken Spot 1 dec-17 17:04:00 JowiHue Devices added for new light LightStrips Keuken dec-17 17:03:58 JowiHue Devices added for new light Hue TV Links dec-17 17:03:57 JowiHue Error: InitDevices: Object reference not set to an instance of an object. dec-17 17:03:56 JowiHue * Connected to bridge Philips hue at 192.168.0.143 dec-17 17:03:53 Plug-In Finished initializing plug-in JowiHue dec-17 17:03:52 JowiHue InitIO:Plugin basic initialisation done dec-17 17:03:52 JowiHue Starting plugin JowiHue 1.0.6.11 dec-17 17:03:52 Info Plugin JowiHue has connected. IP:127.0.0.1:59937
GetBridgeComplete: Conversion from string "Nullable object must have a valu" to type 'Integer' is not valid.
Unhandled Exception: System.Net.WebException: Error getting response stream (Write: The authentication or decryption has failed.): SendFailure ---> System.IO.IOException: The authentication or decryption has failed. ---> Mono.Security.Protocol.Tls.TlsException: Invalid certificate received from server. Error code: 0xffffffff800b010a at Mono.Security.Protocol.Tls.Handshake.Client.TlsServerCertificate.RemoteValidation (Mono.Security.Protocol.Tls.ClientContext context, AlertDescription description) [0x00000] in <filename unknown>:0 at Mono.Security.Protocol.Tls.Handshake.Client.TlsServerCertificate.validateCertificates (Mono.Security.X509.X509CertificateCollection certificates) [0x00000] in <filename unknown>:0 at Mono.Security.Protocol.Tls.Handshake.Client.TlsServerCertificate.ProcessAsTls1 () [0x00000] in <filename unknown>:0 at Mono.Security.Protocol.Tls.Handshake.HandshakeMessage.Process () [0x00000] in <filename unknown>:0 at (wrapper remoting-invoke-with-check) Mono.Security.Protocol.Tls.Handshake.HandshakeMessage:Process () at Mono.Security.Protocol.Tls.ClientRecordProtocol.ProcessHandshakeMessage (Mono.Security.Protocol.Tls.TlsStream handMsg) [0x00000] in <filename unknown>:0 at Mono.Security.Protocol.Tls.RecordProtocol.InternalReceiveRecordCallback (IAsyncResult asyncResult) [0x00000] in <filename unknown>:0 --- End of inner exception stack trace --- at Mono.Security.Protocol.Tls.SslStreamBase.AsyncHandshakeCallback (IAsyncResult asyncResult) [0x00000] in <filename unknown>:0 --- End of inner exception stack trace --- at System.Net.HttpWebRequest.EndGetResponse (IAsyncResult asyncResult) [0x00000] in <filename unknown>:0 at System.Net.HttpWebRequest.GetResponse () [0x00000] in <filename unknown>:0 at System.Net.WebClient.GetWebResponse (System.Net.WebRequest request) [0x00000] in <filename unknown>:0 at System.Net.WebClient.ReadAll (System.Net.WebRequest request, System.Object userToken) [0x00000] in <filename unknown>:0 at System.Net.WebClient.DownloadDataCore (System.Uri address, System.Object userToken) [0x00000] in <filename unknown>:0 10:03:29:8752:[Info]->Plugin JowiHue with instance: has disconnected 10:03:56:5906:[Warning]->I/O interface JowiHue is down, executable is not running, restarting ... Connecting to server at 127.0.0.1... 10:03:59:6768:[Info]->Plugin JowiHue has connected. IP:127.0.0.1:41835 Connected, waiting to be initialized...
sudo apt-get install mono-devel
mozroots --import --ask-remove
Mozilla Roots Importer - version 3.2.8.0 Download and import trusted root certificates from Mozilla's MXR. Copyright 2002, 2003 Motus Technologies. Copyright 2004-2008 Novell. BSD licensed. Downloading from 'http://mxr.mozilla.org/seamonkey/source/security/nss/lib/ckfw/builtins/certdata.txt?raw=1'... Importing certificates into user store... 140 new root certificates were added to your trust store. Import process completed.
