getting a error on long speech again, but this time on playing from wav file
it just drops connection or something...
even if i do use delay after it drops much quicker..
but i have no problems when i stream the same file from my phone...
you can add the ezcast to the list
regards
getting this date..
// i found out a bug on beta 423, when i start the plugin it does find the device in the log but not showing up in the plugin.. so after restart it does not work correct. but it shows up in the plugin again.
so it only speak this text (this is a test 1 2 3 4) when i do (this is a test 1 2 3) it does not speak so anything lower than that does not work. so (21 characters minimum with counted spaces)
regards
getting this date..
DEBUG Date, Thu, 01 Jan 1970 00:03:37 +0000
DEBUG System.IO.IOException: Unable to write data to the transport connection: An established connection was aborted by the software in your host machine. ---> System.Net.Sockets.SocketException: An established connection was aborted by the software in your host machine at System.Net.Sockets.Socket.Send(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags) at System.Net.Sockets.NetworkStream.Write(Byte[] buffer, Int32 offset, Int32 size) --- End of inner exception stack trace --- at System.Net.Sockets.NetworkStream.Write(Byte[] buffer, Int32 offset, Int32 size) at RTSPClient.ExecRequest(String Cmd, String ContentType, String Content, WebHeaderCollection hds, Boolean GetResponse, String& returnCode, Boolean parseHeaderOnError) at RTSPClient.Teardown() Mar-25 11:05:45 AirplaySpeak DEBUG TEARDOWN rtsp://192.168.xx.xxx/0719765704 RTSP/1.0 CSeq: 7 Session: DEADBEEF User-Agent: iTunes/7.6.2 ( Windows;N;) Client-Instance: A9359E46698250B5 Mar-25 11:05:45 AirplaySpeak DEBUG TIMING EXCEPTIONA blocking operation was interrupted by a call to WSACancelBlockingCall Mar-25 11:05:45 AirplaySpeak DEBUG System.Exception: Request failed, read error at RTSPClient.ExecRequest(String Cmd, String ContentType, String Content, WebHeaderCollection hds, Boolean GetResponse, String& returnCode, Boolean parseHeaderOnError) at RTSPClient.Flush(Int32 rtpseq, Int32 rtptime) Mar-25 11:05:45 AirplaySpeak DEBUG FLUSH rtsp://192.168.xx.xxx/0719765704 RTSP/1.0 CSeq: 6 Session: DEADBEEF RTP-Info: seq=11452;rtptime=1425806 User-Agent: iTunes/7.6.2 ( Windows;N;) Client-Instance: A9359E46698250B
Mar-25 13:03:56 AirplaySpeak DEBUG TIMING EXCEPTIONA blocking operation was interrupted by a call to WSACancelBlockingCall Mar-25 13:03:56 AirplaySpeak DEBUG TEARDOWN rtsp://192.168.x.xxx/2473479959 RTSP/1.0 CSeq: 7 Session: DEADBEEF User-Agent: iTunes/7.6.2 ( Windows;N;) Client-Instance: 7F87F9930D79EB7F Mar-25 13:03:56 AirplaySpeak DEBUG System.Exception: Request failed, read error at RTSPClient.ExecRequest(String Cmd, String ContentType, String Content, WebHeaderCollection hds, Boolean GetResponse, String& returnCode, Boolean parseHeaderOnError) at RTSPClient.Flush(Int32 rtpseq, Int32 rtptime) Mar-25 13:03:56 AirplaySpeak DEBUG FLUSH rtsp://192.168.xx.xxx/2473479959 RTSP/1.0 CSeq: 6 Session: DEADBEEF RTP-Info: seq=7746;rtptime=2346215 User-Agent: iTunes/7.6.2 ( Windows;N;) Client-Instance: 7F87F9930D79EB7F Mar-25 13:03:56 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock Mar-25 13:03:56 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() Mar-25 13:03:55 AirplaySpeak DEBUG 17 Speaker.OnQueueEnd() gets the lock Mar-25 13:03:55 AirplaySpeak DEBUG 17 Speaker.OnQueueEnd() Mar-25 13:03:55 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock Mar-25 13:03:55 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() Mar-25 13:03:53 AirplaySpeak DEBUG 10 Speaker.OnCheckStatusTimerEvent() gets the lock Mar-25 13:03:53 AirplaySpeak DEBUG 10 Speaker.OnCheckStatusTimerEvent() Mar-25 13:03:52 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock Mar-25 13:03:52 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() Mar-25 13:03:51 AirplaySpeak DEBUG 10 Speaker.OnCheckStatusTimerEvent() gets the lock Mar-25 13:03:51 AirplaySpeak DEBUG 10 Speaker.OnCheckStatusTimerEvent() Mar-25 13:03:50 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock Mar-25 13:03:50 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() Mar-25 13:03:49 AirplaySpeak DEBUG 10 Speaker.OnCheckStatusTimerEvent() gets the lock Mar-25 13:03:49 AirplaySpeak DEBUG 10 Speaker.OnCheckStatusTimerEvent() Mar-25 13:03:48 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock Mar-25 13:03:48 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() Mar-25 13:03:47 AirplaySpeak DEBUG 10 Speaker.OnCheckStatusTimerEvent() gets the lock Mar-25 13:03:47 AirplaySpeak DEBUG 10 Speaker.OnCheckStatusTimerEvent() Mar-25 13:03:46 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock Mar-25 13:03:46 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() Mar-25 13:03:45 AirplaySpeak DEBUG 10 Speaker.OnCheckStatusTimerEvent() gets the lock Mar-25 13:03:45 AirplaySpeak DEBUG 10 Speaker.OnCheckStatusTimerEvent() Mar-25 13:03:44 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock Mar-25 13:03:44 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() Mar-25 13:03:43 AirplaySpeak DEBUG 10 Speaker.OnCheckStatusTimerEvent() gets the lock Mar-25 13:03:43 AirplaySpeak DEBUG 10 Speaker.OnCheckStatusTimerEvent() Mar-25 13:03:43 SCRAPER *** Scraper Updated *** Mar-25 13:03:42 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock Mar-25 13:03:42 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() Mar-25 13:03:41 AirplaySpeak DEBUG 10 Speaker.OnCheckStatusTimerEvent() gets the lock Mar-25 13:03:41 AirplaySpeak DEBUG 10 Speaker.OnCheckStatusTimerEvent() Mar-25 13:03:40 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock Mar-25 13:03:40 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() Mar-25 13:03:39 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock Mar-25 13:03:39 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() Mar-25 13:03:38 AirplaySpeak DEBUG 10 Speaker.OnCheckStatusTimerEvent() gets the lock Mar-25 13:03:38 AirplaySpeak DEBUG 10 Speaker.OnCheckStatusTimerEvent() Mar-25 13:03:37 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock Mar-25 13:03:37 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() Mar-25 13:03:36 AirplaySpeak DEBUG 10 Speaker.OnCheckStatusTimerEvent() gets the lock Mar-25 13:03:36 AirplaySpeak DEBUG 10 Speaker.OnCheckStatusTimerEvent() Mar-25 13:03:35 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock Mar-25 13:03:35 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() Mar-25 13:03:34 AirplaySpeak DEBUG 10 Speaker.OnCheckStatusTimerEvent() gets the lock Mar-25 13:03:34 AirplaySpeak DEBUG 10 Speaker.OnCheckStatusTimerEvent() Mar-25 13:03:33 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock Mar-25 13:03:33 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() Mar-25 13:03:32 FileControl Automatic File Control is Updated Mar-25 13:03:32 AirplaySpeak DEBUG 10 Speaker.OnCheckStatusTimerEvent() gets the lock Mar-25 13:03:32 AirplaySpeak DEBUG 10 Speaker.OnCheckStatusTimerEvent() Mar-25 13:03:31 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock Mar-25 13:03:31 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() Mar-25 13:03:30 AirplaySpeak DEBUG 10 Speaker.OnCheckStatusTimerEvent() gets the lock Mar-25 13:03:30 AirplaySpeak DEBUG 10 Speaker.OnCheckStatusTimerEvent() Mar-25 13:03:29 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock Mar-25 13:03:29 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() Mar-25 13:03:28 AirplaySpeak DEBUG 10 Speaker.OnCheckStatusTimerEvent() gets the lock Mar-25 13:03:28 AirplaySpeak DEBUG 10 Speaker.OnCheckStatusTimerEvent() Mar-25 13:03:27 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock Mar-25 13:03:27 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() Mar-25 13:03:26 AirplaySpeak DEBUG 10 Speaker.OnCheckStatusTimerEvent() gets the lock Mar-25 13:03:26 AirplaySpeak DEBUG 10 Speaker.OnCheckStatusTimerEvent() Mar-25 13:03:25 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock Mar-25 13:03:25 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() Mar-25 13:03:24 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock Mar-25 13:03:24 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() Mar-25 13:03:23 AirplaySpeak DEBUG 10 Speaker.OnCheckStatusTimerEvent() gets the lock Mar-25 13:03:23 AirplaySpeak DEBUG 10 Speaker.OnCheckStatusTimerEvent() Mar-25 13:03:22 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock Mar-25 13:03:22 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() Mar-25 13:03:21 AirplaySpeak DEBUG 10 Speaker.OnCheckStatusTimerEvent() gets the lock Mar-25 13:03:21 AirplaySpeak DEBUG 10 Speaker.OnCheckStatusTimerEvent() Mar-25 13:03:20 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock Mar-25 13:03:20 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() Mar-25 13:03:19 AirplaySpeak DEBUG 10 Speaker.OnCheckStatusTimerEvent() gets the lock Mar-25 13:03:19 AirplaySpeak DEBUG 10 Speaker.OnCheckStatusTimerEvent() Mar-25 13:03:18 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock Mar-25 13:03:18 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() Mar-25 13:03:17 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock Mar-25 13:03:17 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() Mar-25 13:03:16 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock Mar-25 13:03:16 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() Mar-25 13:03:15 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock Mar-25 13:03:15 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() Mar-25 13:03:14 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock Mar-25 13:03:14 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() Mar-25 13:03:13 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock Mar-25 13:03:13 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() Mar-25 13:03:12 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock Mar-25 13:03:12 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() Mar-25 13:03:11 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock Mar-25 13:03:11 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() Mar-25 13:03:10 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock Mar-25 13:03:10 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() Mar-25 13:03:09 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock Mar-25 13:03:09 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() Mar-25 13:03:08 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock Mar-25 13:03:08 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() Mar-25 13:03:07 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock Mar-25 13:03:07 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() Mar-25 13:03:06 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock Mar-25 13:03:06 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() Mar-25 13:03:05 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock Mar-25 13:03:05 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() Mar-25 13:03:04 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() gets the lock Mar-25 13:03:04 AirplaySpeak DEBUG 9 Speaker.OnCheckStatusTimerEvent() Mar-25 13:03:04 AirplaySpeak DEBUG 16 Speaker.AfterSend() Mar-25 13:03:03 AirplaySpeak DEBUG 16 Speaker.SendSample() gets lock Mar-25 13:03:03 AirplaySpeak DEBUG 16 Speaker.SendSample() Mar-25 13:03:03 AirplaySpeak DEBUG 16 Speaker.BeforeSend() Mar-25 13:03:03 AirplaySpeak DEBUG Server, AirTunes/220.68 Mar-25 13:03:03 AirplaySpeak DEBUG Date, Thu, 01 Jan 1970 00:11:50 +0000 Mar-25 13:03:03 AirplaySpeak DEBUG CSeq, 5 Mar-25 13:03:03 AirplaySpeak DEBUG SET_PARAMETER rtsp://192.168.x.xxx/2473479959 RTSP/1.0 CSeq: 5 Session: DEADBEEF Content-Type: text/parameters Content-Length: 20 User-Agent: iTunes/7.6.2 ( Windows;N;) Client-Instance: 7F87F9930D79EB7F volume: -10.000000 Mar-25 13:03:03 AirplaySpeak DEBUG Audio-Latency, 2205 Mar-25 13:03:03 AirplaySpeak DEBUG Audio-Jack-Status, connected; type=analog Mar-25 13:03:03 AirplaySpeak DEBUG Server, AirTunes/220.68 Mar-25 13:03:03 AirplaySpeak DEBUG Date, Thu, 01 Jan 1970 00:11:50 +0000 Mar-25 13:03:03 AirplaySpeak DEBUG CSeq, 4 Mar-25 13:03:03 AirplaySpeak DEBUG RECORD rtsp://192.168.xx.xxx/2473479959 RTSP/1.0 CSeq: 4 Session: DEADBEEF Range: npt=0- RTP-Info: seq=1202;rtptime=42727 User-Agent: iTunes/7.6.2 ( Windows;N;) Client-Instance: 7F87F9930D79EB7F Mar-25 13:03:03 AirplaySpeak DEBUG Transport, RTP/AVP/UDP;unicast;interleaved=0-1;mode=record;control_port=50752;timing_port=50751;server_port=56588 Mar-25 13:03:03 AirplaySpeak DEBUG Session, DEADBEEF Mar-25 13:03:03 AirplaySpeak DEBUG Date, Thu, 01 Jan 1970 00:11:50 +0000 Mar-25 13:03:03 AirplaySpeak DEBUG Audio-Jack-Status, connected; type=analog Mar-25 13:03:03 AirplaySpeak DEBUG CSeq, 3 Mar-25 13:03:03 AirplaySpeak DEBUG Server, AirTunes/220.68 Mar-25 13:03:03 AirplaySpeak DEBUG SETUP rtsp://192.168.xx.xxx/2473479959 RTSP/1.0 CSeq: 3 Transport: RTP/AVP/UDP;unicast;interleaved=0-1;mode=record;control_port=50752;timing_port=50751 User-Agent: iTunes/7.6.2 ( Windows;N;) Client-Instance: 7F87F9930D79EB7F Mar-25 13:03:03 AirplaySpeak DEBUG Audio-Jack-Status, connected; type=analog Mar-25 13:03:03 AirplaySpeak DEBUG Server, AirTunes/220.68 Mar-25 13:03:03 AirplaySpeak DEBUG Date, Thu, 01 Jan 1970 00:11:50 +0000 Mar-25 13:03:03 AirplaySpeak DEBUG CSeq, 2 Mar-25 13:03:03 AirplaySpeak DEBUG ANNOUNCE rtsp://192.168.xx.xxx/2473479959 RTSP/1.0 CSeq: 2 Content-Type: application/sdp Content-Length: 182 User-Agent: iTunes/7.6.2 ( Windows;N;) Client-Instance: 7F87F9930D79EB7F v=0 o=iTunes 2473479959 0 IN IP4 192.168.xx.xxx s=iTunes c=IN IP4 192.168.xx.xxx t=0 0 m=audio 0 RTP/AVP 96 a=rtpmap:96 AppleLossless a=fmtp:96 352 0 16 40 10 14 2 255 0 0 44100 Mar-25 13:03:03 AirplaySpeak DEBUG Server, AirTunes/220.68 Mar-25 13:03:03 AirplaySpeak DEBUG Date, Thu, 01 Jan 1970 00:11:50 +0000 Mar-25 13:03:03 AirplaySpeak DEBUG CSeq, 1 Mar-25 13:03:03 AirplaySpeak DEBUG Public, ANNOUNCE, SETUP, RECORD, PAUSE, FLUSH, TEARDOWN, OPTIONS, GET_PARAMETER, SET_PARAMETER, POST, GET Mar-25 13:03:03 AirplaySpeak DEBUG OPTIONS * RTSP/1.0 CSeq: 1 User-Agent: iTunes/7.6.2 ( Windows;N;) Client-Instance: 7F87F9930D79EB7F Mar-25 13:03:03 AirplaySpeak DEBUG 16 Speaker.Reset() gets the lock Mar-25 13:03:03 AirplaySpeak DEBUG 16 Speaker.Reset() Mar-25 13:03:03 AirplaySpeak INFO (SpeakerClient1): C:\voice.wav
