Device Location
    Device Location
    I am using the trial version, and when I insert (Kitchen) as the location of speaker 1, it shows up. But when I restart HS, It goes back to the default of IRPSpeak. How do I set it up so that it stays (Kitchen) for speaker 1?
    I am not sure why that is happing to you, try using the "Re-Create Devices" button on the Config page, it should read the INI file either way and populate the device names correctly, but let me know if the re-create button solves this. If the problem persists please enable LogToFile and Debug from the config page and send me the results.
    This is a copy of my INI file and it seems to work fine, just as an example:
    [Config]
    Debug=False
    Logging=False
    [Delays]
    PreDelay=0
    PostDelay=200
    [Volume]
    VolSoft=25
    VolNorm=50
    VolLoud=75
    VolMax=100
    VolRange=100
    [Speakers]
    Relay1=Garage
    Relay2=Kitchen
    Relay3=Katelyns
    Relay4=MediaRm
    Relay5=ExerciseRm
    Relay6=GameRm
    Relay7=NotUsed-7
    Relay8=NotUsed-8
    -Larry
    A member of "The HA Pioneer Group", MyWebSite
    Plugins:
    VWS, AB8SS, lrpSpeak, Calendar, Arduino, Harmony, BlueIris, Sprinklers, ZipBackup...
    Hardware:
    Intel NUC8i7BEH1 running Windows 10 Pro headless, HS3 Pro, Plex running on Synology dual High Availability DS-1815+ NAS (24Tb each), Synology Surveillance Station running on DS-416 Slim (8Tb), Samsung SmartThings, Google Home, Alexa, Hubitat Elevation, ZNET, Ubiquiti UniFi Network, Davis Vantage Pro II Weather Station. Whole house speaker system using a couple of AB8SS switches. Vantage Pro II Weather Station, Rain8Net Sprinklers, Hubitat Elevation, Google Home, Alexa, DSC Security System, Ubiquiti UniFi Network.
      It seemed to work, Thanks for the sample and your quick reply.
