Go Back   HomeSeer Message Board > Security Systems Plug-ins > Security System Discussion > HomeSeer DSC Plug-in
HomeSeer DSC Plug-in HomeSeer DSC plug-in for Power Series security panels
  #81
Old April 10th, 2014, 05:11 PM
Dafunktyfunk's Avatar
Dafunktyfunk Dafunktyfunk is offline
Right, I was just hoping since you had the code you could fix what HS just abandoned...
We were promised a fix but AFTER the release of HS3. They said, we are really busy with HS3 but as soon as that launches, we can go back and fix this little bugs. Then, they just said, Nah... we are done...
Can you help at all?
Transitioning to HS3Pro .298 - WinXPEmbedded
  #82
Old April 11th, 2014, 08:17 AM
Sgt. Shultz's Avatar
Sgt. Shultz Sgt. Shultz is offline
You might want to take a look at my signature.
Wade
I know nothing...., nothing!!!
  #83
Old April 11th, 2014, 12:40 PM
Wade, I know who you are and where you work. I was hoping that since this is your code, you would want to make sure it was clean.
I know that programmers' code is like their children and most of them would not want bad code out in the wild...
It was just a hope; a hail-mary...
Oh well...
  #84
Old May 12th, 2014, 01:49 AM
gear gear is offline
Triggers from Zone Restorals
Originally Posted by NicolaiL View Post
That sounds really good!
I have one more request I failed to mention earlier ...
... would you be able to speed up processing so it takes less time for a zone activation to be reflected in HS3? I ask because I trigger based on zone activations to turn light on and I want the minimum possible delay.
Cheers
Nicolai
NicolaiL,
Have you tested Zone Open/Restoral triggers in 3.0.0.34?
I have an event using: IF the response code received is Zone Opened(609) for any zone THEN Speak Zone Opened.
However it never triggers... Do you use a similar trigger or are you making a VB call?
Gear
  #85
Old May 13th, 2014, 11:02 AM
Are you seeing the status of that zone change on the device management page?
What does the log look like?
  #86
Old May 13th, 2014, 09:48 PM
Sgt,
The devices are changing state properly. However the events based on Zone Open/Restoral triggers are not triggering and there are no related entries in the log file.
I've found a work around and that is simply to use triggers based on the devices changing state:
IF Front Door changes and becomes a value in the range of 609 to 609
THEN ...
This built-in trigger works fine.
Thanks, Gear
  #87
Old May 14th, 2014, 11:24 AM
I was asking about the devices, as they get the same response values the trigger does.
I was interested in the log file in case an error had occurred in your event process somewhere.
I tested the trigger for a single zone as well as all zones and it ran the action I set up with no issues.
  #88
Old June 14th, 2014, 03:26 AM
connoleg connoleg is offline
Is there any chance of the DSC plugin for HS3 linux?
Gary
  #89
Old June 14th, 2014, 09:39 AM
rjh's Avatar
rjh rjh is offline
HomeSeer Technologies
Yes, we plan on offering this on Linux, should be in the updater soon, just need to test.
Gary
Rich,
  #90
Old June 24th, 2014, 07:07 PM
Mack1979 Mack1979 is offline
This thread has gone quiet but not seen any updates lately. As far as I can tell with the latest version we've lost status names. Luckily for me I'd set up my events already which have converted themselves to the values instead but I can't set up new ones.
Also I used to trigger events to email me if specific users disarmed the panel but now it only has user 0003 and seems to ignore the name to pass code position lookup in the plugin config. Is this wip or is this just me?
Sent from my Nexus 5 using Tapatalk
  #91
Old July 7th, 2014, 12:21 AM
Bump.
  #92
Old September 11th, 2014, 03:46 PM
jorgen
Guest
Posts: n/a
HS3 DSC Linux
I cant find DSC in the Hs3 Linux plug-in manager?
  #93
Old September 18th, 2014, 10:12 PM
happnatious1's Avatar
happnatious1 happnatious1 is offline
Is anybody else not able to load 3.0.0.43. It says it's successful be version is still 3.0.0.42.
  #94
Old September 19th, 2014, 03:13 AM
NicolaiL's Avatar
NicolaiL NicolaiL is offline
Super Seer
Yes, I'm seeing that too. I think it installs, but the developer may not have updated the file version in his source code so it is still displaying the old version number.
I guess we should log a bugzilla I just haven't gotten round to it.
  #95
Old September 19th, 2014, 09:43 AM
RJS RJS is offline
I am getting log errors when I try to update:
Sep-19 6:59:55 AM Plug-In Finished initializing plug-in DSC Security Sep-19 6:59:55 AM DSC Security Abandoning COM Thread Start: The given port name does not start with COM/com or does not resolve to a valid serial port.Parameter name: portName Sep-19 6:59:55 AM DSC Security Error in COM Thread Start: The given port name does not start with COM/com or does not resolve to a valid serial port.Parameter name: portName Sep-19 6:59:55 AM DSC Security Error in COM Thread Start: The given port name does not start with COM/com or does not resolve to a valid serial port.Parameter name: portName Sep-19 6:59:55 AM DSC Security Error in COM Thread Start: The given port name does not start with COM/com or does not resolve to a valid serial port.Parameter name: portName Sep-19 6:59:55 AM DSC Security Error in COM Thread Start: The given port name does not start with COM/com or does not resolve to a valid serial port.Parameter name: portName Sep-19 6:59:55 AM DSC Security Error in COM Thread Start: The given port name does not start with COM/com or does not resolve to a valid serial port.Parameter name: portName Sep-19 6:59:55 AM DSC Security Error in COM Thread Start: The given port name does not start with COM/com or does not resolve to a valid serial port.Parameter name: portName Sep-19 6:59:53 AM Info Plugin DSC Security has connected. IP:127.0.0.1:1832 Sep-19 6:59:52 AM Updater Re-initializing plugin after update. Sep-19 6:59:52 AM Updater Install/Update of package HomeSeer DSC Security was successful. Sep-19 6:59:52 AM Updater Copying file: C:\Program Files\HomeSeer HS3\html\DSC\Help.htm Sep-19 6:59:52 AM Updater Extraction Complete. Sep-19 6:59:52 AM Updater Extracting files from zip file: DSC_Images.zip Sep-19 6:59:52 AM Updater Copying file: C:\Program Files\HomeSeer HS3\HSPI_DSC.exe Sep-19 6:59:52 AM Updater Installing package HomeSeer DSC Security Sep-19 6:59:52 AM Updater Update HSPI_DSC.exe downloaded successfully Sep-19 6:59:52 AM Updater Downloading update: HomeSeer DSC Security Sep-19 6:59:52 AM Info Plugin DSC Security with instance: has disconnected Sep-19 6:59:52 AM Updater Plugin is loaded, unloading before updating. Sep-19 6:59:52 AM Updater Starting download of updates
Did you guys post a bug? What is the number. Otherwise I'll post one.
  #96
Old September 19th, 2014, 09:49 AM
RJS RJS is offline
I didn't see a bug report so I posted one: Bug 2225
  #97
Old September 19th, 2014, 10:12 AM
3.0.0.43 is in the updater now.
  #98
Old September 19th, 2014, 10:48 AM
RJS RJS is offline
See Bugzilla 2225 for additional comments after this update.
  #99
Old September 19th, 2014, 05:43 PM
RJS RJS is offline
I guess Homeseer is closed for the weekend (and they have the right to close) but I'm stuck with this plugin that doesn't work. I need to go on travel and the alarm system is totally offline from HS3's standpoint.
I need to roll back to the previous version of the plugin. Anyone know where it can be found? (version 3.0.0.42)
  #100
Old September 19th, 2014, 08:33 PM
sparkman's Avatar
sparkman sparkman is offline
Older versions should be in your updates3 folder.
Cheers
Al
