Where can I find the manual/directions for using HSTouch Designer?
HSTouch Designer Manual
Originally posted by jrjmpls7 View PostWhere can I find the manual/directions for using HSTouch Designer?
You are much better off watching the youtube videos.
http://www.youtube.com/user/HomeSeerOfficial
The Designer has an almost "Visual Studio" feel with properties, elements, etc. Just much more geared towards HS (obviously). So, if you've used Visual Studio, you will handle it fine.HS4Pro on a Raspberry Pi4
HSTouch Clients: 1 Android
The instructions for the external cameras are in the store page (might be the same for the internal camera, no idea http://store.homeseer.com/store/Fosc...888C194.aspx);
This camera is supported in HSTouch. To add this camera to any HSTouch screen, add an image element to your screen and set the ImageURLNormal to:
http://CAMIP:80/snapshot.cgi?user=admin&pwd=pass
Replace "CAMIP" with the IP address of your camera. Change "admin" to the user you have set, and "pass" to the password. If you did not change any default settings, the user is "admin" and the password is blank.
Set the IsVideo property to TRUE so you get realtime video from the camera.
