From time to time I find the following error message in my HS2 log file:
1/28/2014 1:11:28 AM ~!~Script~!~Script PH_RFXCharts.vben is currently running, waiting for it complete before its run again
It appears to be non-fatal as the charts are working fine, though the message itself seems to imply that PH_RFXCharts.vben was invoked while it was already running. But, AFAIK, it is only invoked at StartUp and Shutdown via the respective script files.
But, not willing to let well enough alone, I temporarily renamed PH_RFXCharts.vben and got the following in the HS2 log file:
1/28/2014 3:58:08 PM ~!~Error~!~Initializing script run: File 'D:\Program Files\HomeSeer HS2\scripts\PH_RFXCharts.vben' not found.
1/28/2014 3:58:09 PM ~!~Error~!~Initializing script run: File 'D:\Program Files\HomeSeer HS2\scripts\PH_RFXCharts.vben' not found.
1/28/2014 3:58:10 PM ~!~Error~!~Initializing script run: File 'D:\Program Files\HomeSeer HS2\scripts\PH_RFXCharts.vben' not found.
1/28/2014 3:58:14 PM ~!~Error~!~Initializing script run: File 'D:\Program Files\HomeSeer HS2\scripts\PH_RFXCharts.vben' not found.
1/28/2014 3:58:16 PM ~!~Error~!~Initializing script run: File 'D:\Program Files\HomeSeer HS2\scripts\PH_RFXCharts.vben' not found.
1/28/2014 3:58:20 PM ~!~Error~!~Initializing script run: File 'D:\Program Files\HomeSeer HS2\scripts\PH_RFXCharts.vben' not found.
1/28/2014 3:58:21 PM ~!~Error~!~Initializing script run: File 'D:\Program Files\HomeSeer HS2\scripts\PH_RFXCharts.vben' not found.
Of course, the fact that errors ensued is not surprising, but the immediacy and the number errors was surprising. It appears that PH_RFXCharts.vben is being invoked on a periodic basis by some process at a fairly high frequency.
Note that PF_RFXCOM2.vben is event driven once per hour at 1 minute past the hour.
Given that I'm running on a underpowered HT2, it's not surprising that occasionally PH_RFXCharts.vben doesn't complete in a timely fashion. By the same token, I'd like to conserve what CPU cycles I have.
So, (1) is this the expected behavior, i.e. PH_RFXCharts.vben is running at a high frequency? (2) If yes, can it be slowed down? TIA
Mark
nb: RFXCHARTS 1.0.0.10
Mark
