Does the HS3 Home Troller have the TV and Game Timer on it? I am going to be using one for an install for a family with an autistic child and they need this feature.
TV and Game Timer on HS3
Originally posted by Phaeton View PostCant you create this with scripts? You measure the powerusage. When usage higer than xxx the start timer which enables virtual device. If usage higer than and virtual device is and turn tv off.
Verstuurd vanaf mijn GT-I9300 met Tapatalk
HS3 does include a new feature of timers and counters. Perhaps you could use this? Create a timer called "daily TV use" and then create events that start, stop and resume it when modules are turned on a off. You can then create more events to issue TTS announcements to alert the user that the TV is about to turn off. You can create another event to reset the timer each day.
