I've finally migrated to HS3, overall I'm loving HS3 and also Stipus' PLCBUS plugin for HS3. But I've encountered a very annoying issue.. I hope it's something simple to fix or I've just overlooked something:
The problem is about PLCBUS scene activation on HS3.... so I've already reprogrammed a couple of my existing scenes with this new plugin. Before the reprogram, the scenes turned on very quickly.. near instantly... but now, it turns on very slow (10-20+ seconds delay!). Why is this?
I have one scene that includes 5 devices, delayed for 20-25 seconds on both Turn ON and OFF. I have another scene that only includes 2 devices, this one gets delayed for 'only' 10-15 seconds on both ON and OFF operation.
I've checked for signal:noise on each of the modules involved (all 7 of them), two of them have low signal(11-13), the other three are good (17-22)... as for the noise, they're all 0.
I've also tried turning WaitForAck off, that didn't help.
Log (with plcbus debug mode: on)
(clicked 'ON' at 2:21:17, actual lights turned on (all together) at around 2:21:50)
PS: On the positive side, it seems that this plugin ensures 100% activation of all the devices. I wonder if the mechanism can be changed, so it just fires the scene activation immediately like it used to do, then do the correction afterward.. only if needed.
Mar-25 2:21:51 PM PLCBUS Debug InterfaceStatus[] - selected=[True] configured=[True] connected=[True] Mar-25 2:21:49 PM PLCBUS Debug InterfaceStatus[] - selected=[True] configured=[True] connected=[True] Mar-25 2:21:47 PM PLCBUS Debug InterfaceStatus[] - selected=[True] configured=[True] connected=[True] Mar-25 2:21:45 PM PLCBUS Debug Rcvd Ack: (138) M5 On Data1:100 Data2:0 Tx:False AckReq:True Ack:True IDreq:False Id:False 3PhReq:True RiscOK:False PlcBusOK:False Mar-25 2:21:45 PM PLCBUS Debug Sent: (138) M5 On Data1:100 Data2:0 Tx:True AckReq:True Ack:False IDreq:False Id:False 3PhReq:True RiscOK:True PlcBusOK:True Mar-25 2:21:43 PM PLCBUS Device Device [138-M5] status set to [On] Mar-25 2:21:43 PM PLCBUS Debug Sending: (138) M5 On Data1:0 Data2:0 Tx:False AckReq:True Ack:False IDreq:False Id:False 3PhReq:True RiscOK:False PlcBusOK:False Mar-25 2:21:39 PM PLCBUS Device Device [138-H11] status set to [On] Mar-25 2:21:34 PM PLCBUS Device Device [138-P3] status set to [On] Mar-25 2:21:32 PM PLCBUS Device Device [138-P2] status set to [On] Mar-25 2:21:26 PM PLCBUS Device Device [138-P10] status set to [On] Mar-25 2:21:22 PM PLCBUS Device Device [138-G1] status set to [On] Mar-25 2:21:22 PM PLCBUS Debug SetIO[] name=[Scene : Night Lights (Indoor)] address=[138-M5] type=[PlcBus Scene] controlValue=[101] Mar-25 2:21:22 PM Device Control Device: Hall Scene : Night Lights (Indoor) to On (101) by/from: CAPI Control Handler Mar-25 2:21:21 PM PLCBUS Debug InterfaceStatus[] - selected=[True] configured=[True] connected=[True] Mar-25 2:21:19 PM PLCBUS Debug InterfaceStatus[] - selected=[True] configured=[True] connected=[True] Mar-25 2:21:17 PM PLCBUS Debug InterfaceStatus[] - selected=[True] configured=[True] connected=[True]
