Thanks for building a great generic modem phone plugin, I own the HS2 version and I decided this weekend to upgrade to HS3 since I moved to a new house and have been testing the UltraCID3 plugin with a USRobotics USB Modem. I also have a 'Doorbell FON' system installed at the front door with one of these control boxes:
http://www.homephone.com/PDF%20cutsh...20cutsheet.pdf
With this system, when someone presses the doorbell button, the house phone rings and because the doorbell button has an integrated speaker/mic, I can speak (and hear) the person at the door through my land line.
What I would like to do with UltraCID3 is to trigger an email when the doorbell button is pressed. Just to note, I am fluent with VB scripting and have migrated all of my HS2 scripts HS3. I've tried several combinations of triggering based on Ring Number, the trigger works fine each time the Doorbell FON system rings, but the name and CID always contain the previous caller information and not the non-CID doorbell 'Ring'. Is there anyway I can test on the current ring not having a valid CID? Or other code suggestion? thx, Glenn
