Could you provide me any information on what may be causing this issue?
The Arduino plugin seems to be working fine otherwise.
Thanks in advance;
Issue:
HS3 web server locks up. HS still functions. You just can not get to the web interface.
It runs for about a day and 1/2 before it happens. Appears to be a Arduino Plugin issue.
Hardware/Software Configuration:
HS3 ZEE S2 Edition 3.0.0.280 on Raspberry PI2, Arduino -Sunfounder Uno, W5100 Ethernet
Troubleshooting:
Disabled off Arduino plugin. HS3 ran for a week with no errors.
HS memory gradually increases from about 90 MB to 200MB when the issue starts happening
Errors when it locks up:
AcceptCallback: Too many open files
Log:
2016-03-18 21:01:36 Error AcceptCallback: Too many open files
2016-03-18 21:01:32 Warning Log Database failed to open,? waiting then retrying...unable to open database file
2016-03-18 21:01:27 Warning Log Database failed to open,? waiting then retrying...unable to open database file
2016-03-18 21:01:27 Error An Invalid Database state was detected when attempting to retrieve the database version.
Thanks in advance;
Issue:
Troubleshooting:
Log:
