HomeSeer Mobile Feature Requests
I suggest you look at the iOS app for iDevices. IMO this is quite well done. Note that it is fully compatible with Apple Home app.
Steve QHomeSeer Version: HS3 Pro Edition 3.0.0.368, Operating System: Microsoft Windows 10 - Home, Number of Devices: 373, Number of Events: 666, Enabled Plug-Ins
Attached is a post I submitted in 2007 for an Apple iTouch controller for HS2.
https://forums.homeseer.com/showpost...9&postcount=36
Also attached is a page from the current Apple Home app.
Kinda similar!
Steve QLast edited by Steve Q; March 15, 2018, 05:00 PM.HomeSeer Version: HS3 Pro Edition 3.0.0.368, Operating System: Microsoft Windows 10 - Home, Number of Devices: 373, Number of Events: 666, Enabled Plug-Ins
Originally posted by mikej8111 View PostI installed HSPro about a month ago. I was on the east coast working.I'm back home now spending 5-10 mins a day playing a little with it. A few things..
Does Homeseer have ability to work Apple Watch ?
Geo fencing ?HS4 Pro, 4.2.19.16 Windows 10 pro, Supermicro LP Xeon
Originally posted by Steve Q View PostRather than reinvent a new app, I think the Fraggel plugin would provide pretty much everything that most iOS users want. This was an outstanding plugin. Surely it would be easier to get Apple approval for the Fraggel plugin than starting from scratch to create a new app which would also need Apple approval!
Steve Q
I would much rather have HomeKit integrated into homeseer than use a plugin. It should be on an equal footing with Alexa and Google Assistant. The two voice assistants that most people have are not officially supported by homeseer. Not that any one uses Cortana. But iOS users definitely use Siri.
Sent from my iPhone using Tapatalk_______________________________________________
Originally posted by rjh View PostWe have looked at many HA apps, and while there isn't a standard, I did not find one that forced a login. I would say if you want security, make sure your phone auto locks.
But that being said, I would like to hear feedback from others. Would you want a secondary login to get into this app? I would never use it as my phone locks automatically and I don't want the extra step. If there is interest, we could make this an option.
I'd not use this since I lock my phone.HS4 Pro on Shuttle NC10U, Win10; Z-NET
Number of Devices: 1005
Number of Events: 293
Plug-Ins: BLLock, DirecTv, EasyTrigger, Honeywell WiFi Thermostat, Marquis monoprice Amp, MeiHarmonyHub, PHLocation2, Pushover 3P, UltraM1G3, rnbWeather, Worx Landroid, Z-Wave
External applications: Homebridge-homeseer, Geofency, EgiGeoZone.
Originally posted by rjh View PostQ: Will it require MyHS?
A: No, you can easily log in with your MyHS credentials, or you can connect directly to your HS3 system using its IP or DNS name.
The IOS blue iris app is an example of an app that manages this seamlesslyHS4 Pro on Shuttle NC10U, Win10; Z-NET
Originally posted by jlrichar View PostI would much rather have HomeKit integrated into homeseer than use a plugin. It should be on an equal footing with Alexa and Google Assistant. The two voice assistants that most people have are not officially supported by homeseer. Not that any one uses Cortana. But iOS users definitely use Siri.
Sent from my iPhone using TapatalkHomeSeer Version: HS3 Pro Edition 3.0.0.368, Operating System: Microsoft Windows 10 - Home, Number of Devices: 373, Number of Events: 666, Enabled Plug-Ins
Integrated like google home, Alexa, IFTTT. When those stop working you can place a help ticket with HS and they fix it.
This is problematic, what if you want to connect to a vacation home, but you are in your current home, which system does it auto connect to? I guess a setup setting needs to be set to tell the app how to connect, like Auto (for the case where you only have one system), and a prompt so it prompts you for when you have multiple systems. There could be a mode for when it cannot get an Internet connection it then looks for a local system. Or an option so it always looks for a local system first. More settings to complicate users, something we are trying to get away from. Any setting like this will need to go under an "Advanced" setting area.
Originally posted by jmaddox View PostMy request would be to autosense lan vs wan so HS automatically chooses the correct login between using my local ip vs myhs.
Originally posted by rjh View PostI don't believe developers have access to Siri yet, but I will check. The android version will have voice input.
Your IOS device uses touch ID to log into the device. Why would you want to have to log in again to this app? Not many apps do that, other than financial type apps.
https://developer.apple.com/sirikit/
HS3 3.0.0.420 & HSTouch 3.0.55 with 700 Devices, 358 Events
Plugin's:
BLBackup, BLOccupied, BLShutdown, EasyTrigger, Ecobee,
weatherXML, Jon00 Alexa Helper, Network Monitor, Z-Wave 3.0.1.200HS4 4.2.6.0 &HSTouch Designer 3.0.80
Plugin's:
BLBackup, BLOccupied, BLShutdown, EasyTrigger, Ecobee, Nest, AK Bond
weatherXML, Jon00 Alexa Helper, Network Monitor, MyQ, Z-Wave
Originally posted by rmasonjr View PostI vote No.
Having app-level authentication after unlock would be cumbersome. The only apps I have on my phone that does this now are banking apps and samsung pay.
Ditto
Plugin's:
Plugin's:
