May-20 11:35:52 Error Compiling script C:\Program Files (x86)\HomeSeer HS3\scripts\Traccar.vb: Type 'MySqlException' is not defined.
May-20 11:35:52 Error Compiling script C:\Program Files (x86)\HomeSeer HS3\scripts\Traccar.vb: Type 'MySqlDataReader' is not defined.
May-20 11:35:52 Error Compiling script C:\Program Files (x86)\HomeSeer HS3\scripts\Traccar.vb: Type 'MySqlDataAdapter' is not defined.
May-20 11:35:52 Error Compiling script C:\Program Files (x86)\HomeSeer HS3\scripts\Traccar.vb: Type 'MySqlConnection' is not defined.
May-20 11:35:52 Error Compiling script C:\Program Files (x86)\HomeSeer HS3\scripts\Traccar.vb: Type 'MySqlCommand' is not defined.
May-20 11:35:52 Error Compiling script C:\Program Files (x86)\HomeSeer HS3\scripts\Traccar.vb: Namespace or type specified in the Imports 'Newtonsoft.Json.Linq' doesn't contain any public member or cannot be found. Make sure the namespace or the type is defined and contains at least one public member. Make sure the imported element name doesn't use any aliases.
May-20 11:35:52 Error Compiling script C:\Program Files (x86)\HomeSeer HS3\scripts\Traccar.vb: Namespace or type specified in the Imports 'Newtonsoft.Json' doesn't contain any public member or cannot be found. Make sure the namespace or the type is defined and contains at least one public member. Make sure the imported element name doesn't use any aliases.
May-20 11:35:52 Error Compiling script C:\Program Files (x86)\HomeSeer HS3\scripts\Traccar.vb: Namespace or type specified in the Imports 'MySql.Data.MySqlClient' doesn't contain any public member or cannot be found. Make sure the namespace or the type is defined and contains at least one public member. Make sure the imported element name doesn't use any aliases.
May-20 11:35:52 Error Compiling script C:\Program Files (x86)\HomeSeer HS3\scripts\Traccar.vb: Namespace or type specified in the Imports 'System.Core' doesn't contain any public member or cannot be found. Make sure the namespace or the type is defined and con
does the above mean anything to anyone with script knowledge? driving me mad trying to resolve it now spent weeks!
