Voicemail via HSTouch?
Hello Marty - I just tried adjusting the "EOList" (not "L") value to 4, then 6, and back to 5. Each time it worked fine. The "if L = TotalLimit" line can be deleted. It was a remnant from my cut and paste. (yes, it's crude coding!) Did you make other changes? If so, I'd suggest going back to the original and testing it as-is.
Regards
Matt
Hello Matt,
I apologize for the confusion. Apparently it was the lack of my scripting knowledge. After more calls came in, the list filled up. I'm not sure why and how, as my log goes back to 2006. Perhaps with each call of the script, only one record gets added. So to get 10 records, I'd have to run the script 10 times.
I have one more question.
Even consider I can see the "<BR />" in the
strDeviceString = strDeviceString & pTime & "] " & "<BR />"
line, when I tried to put the device string into HSTouch, it will not format properly. It looks like the breaks are not there. Any ideas??
Marty
Marty,
I was looking at this script too (thanks Matt!) and realized that the number of calls you will receive back is EOList MINUS the number of those lines that are NOT incoming calls - the script will look at the last EOList number of lines but will ignore ~!~Info~! lines (outgoing). That's likely why you are not seeing the full number of calls you are requesting.Mike
Phone_Recent_Calls.txt
I got some error when running the script. Is my callers.log bad?
PHP Code:16/07/2009 15:54:58 - Error - Error in CIDNumber: Value cannot be null.Parameter name: Argument 'Array' is Nothing.
16/07/2009 15:54:58 - Error - Error in CIDName: Value cannot be null.Parameter name: Argument 'Array' is Nothing.
PHP Code:27/05/2009 12:52:04 PM ~!~Caller ID~!~Line: 1 Number: 099950210 Name:
27/05/2009 12:53:59 PM ~!~Caller ID~!~Line: 1 Number: 0344544530 Name:
27/05/2009 12:59:48 PM ~!~Caller ID~!~Line: 1 Number: 099950210 Name:
27/05/2009 13:01:42 PM ~!~Caller ID~!~Line: 1 Number: 099950210 Name:
27/05/2009 13:10:57 PM ~!~Caller ID~!~Line: 1 Number: 0766277677 Name:
27/05/2009 13:11:26 PM ~!~Caller ID~!~Line: 1 Number: 0766277677 Name:
27/05/2009 14:30:24 PM ~!~Caller ID~!~Line: 1 Number: 099950210 Name:
27/05/2009 14:45:03 PM ~!~Caller ID~!~Line: 1 Number: 099950210 Name:
27/05/2009 14:49:53 PM ~!~Caller ID~!~Line: 1 Number: 0344544530 Name:
27/05/2009 14:54:47 PM ~!~Caller ID~!~Line: 1 Number: 099950210 Name:
27/05/2009 14:56:50 PM ~!~Caller ID~!~Line: 1 Number: 099950210 Name:
27/05/2009 14:58:57 PM ~!~Caller ID~!~Line: 1 Number: 099950210 Name:
27/05/2009 15:02:43 PM ~!~Caller ID~!~Line: 1 Number: 099950210 Name:
27/05/2009 15:03:46 PM ~!~Caller ID~!~Line: 1 Number: 099950210 Name:
27/05/2009 17:15:33 PM ~!~Caller ID~!~Line: 1 Number: 0457628294 Name:
27/05/2009 20:35:01 PM ~!~Caller ID~!~Line: 1 Number: 0457628294 Name:
28/05/2009 10:24:47 AM ~!~Caller ID~!~Line: 1 Number: 0344544530 Name:
28/05/2009 10:32:00 AM ~!~Caller ID~!~Line: 1 Number: 0344544530 Name:
28/05/2009 10:36:48 AM ~!~Caller ID~!~Line: 1 Number: 099950210 Name:
28/05/2009 10:37:46 AM ~!~Caller ID~!~Line: 1 Number: 099950210 Name:
28/05/2009 10:41:26 AM ~!~Caller ID~!~Line: 1 Number: 0344544530 Name:
28/05/2009 10:53:50 AM ~!~Caller ID~!~Line: 1 Number: 099950210 Name:
28/05/2009 10:56:03 AM ~!~Caller ID~!~Line: 1 Number: 099950210 Name:
28/05/2009 10:58:40 AM ~!~Caller ID~!~Line: 1 Number: 099950210 Name:
28/05/2009 11:55:22 AM ~!~Caller ID~!~Line: 1 Number: 0344544530 Name:
28/05/2009 12:00:10 PM ~!~Caller ID~!~Line: 1 Number: 099950210 Name:
28/05/2009 12:05:56 PM ~!~Caller ID~!~Line: 1 Number: 099950210 Name:
28/05/2009 17:28:14 PM ~!~Caller ID~!~Line: 1 Number: 0734725543 Name:
28/05/2009 17:29:52 PM ~!~Caller ID~!~Line: 1 Number: 0734725543 Name:
02/06/2009 16:11:59 PM ~!~Caller ID~!~Line: 1 Number: 040133565 Name:
02/06/2009 18:39:24 PM ~!~Caller ID~!~Line: 1 Number: 0853527751 Name:
03/06/2009 22:33:21 PM ~!~Caller ID~!~Line: 1 Number: 0344544530 Name:
03/06/2009 22:39:36 PM ~!~Caller ID~!~Line: 1 Number: 0344544530 Name:
03/06/2009 22:43:27 PM ~!~Caller ID~!~Line: 1 Number: 0344544530 Name:
04/06/2009 15:50:31 PM ~!~Caller ID~!~Line: 1 Number: anonymous Name:
04/06/2009 19:34:09 PM ~!~Caller ID~!~Line: 1 Number: 0547757273 Name:
05/06/2009 12:23:22 PM ~!~Caller ID~!~Line: 1 Number: 0705328690 Name:
07/06/2009 13:03:38 PM ~!~Caller ID~!~Line: 1 Number: 040133565 Name:
07/06/2009 17:40:43 PM ~!~Caller ID~!~Line: 1 Number: 0547757260 Name:
08/06/2009 06:51:00 AM ~!~Caller ID~!~Line: 1 Number: 0344544530 Name:
08/06/2009 17:46:55 PM ~!~Caller ID~!~Line: 1 Number: 040133565 Name:
09/06/2009 09:37:46 AM ~!~Caller ID~!~Line: 1 Number: anonymous Name:
10/06/2009 14:33:30 PM ~!~Caller ID~!~Line: 1 Number: 040133565 Name:
10/06/2009 18:02:22 PM ~!~Caller ID~!~Line: 1 Number: 0547757260 Name:
10/06/2009 20:34:11 PM ~!~Caller ID~!~Line: 1 Number: 040133565 Name:
11/06/2009 17:32:29 PM ~!~Caller ID~!~Line: 1 Number: 0344544530 Name:
13/06/2009 12:24:46 PM ~!~Caller ID~!~Line: 1 Number: 040133565 Name:
14/06/2009 18:34:14 PM ~!~Caller ID~!~Line: 1 Number: 0921342915 Name:
15/06/2009 13:27:55 PM ~!~Caller ID~!~Line: 1 Number: 099950210 Name:
15/06/2009 13:28:20 PM ~!~Caller ID~!~Line: 1 Number: 0344544530 Name:
15/06/2009 13:28:48 PM ~!~Caller ID~!~Line: 1 Number: 099950210 Name:
15/06/2009 13:31:49 PM ~!~Caller ID~!~Line: 1 Number: 099950210 Name:
16/06/2009 17:29:08 PM ~!~Caller ID~!~Line: 1 Number: 040133565 Name:
16/06/2009 17:31:18 PM ~!~Caller ID~!~Line: 1 Number: 0547757273 Name:
16/06/2009 17:58:54 PM ~!~Caller ID~!~Line: 1 Number: 0462705102 Name:
16/06/2009 19:05:26 PM ~!~Caller ID~!~Line: 1 Number: 0344544530 Name:
16/06/2009 19:07:42 PM ~!~Caller ID~!~Line: 1 Number: 099950210 Name:
16/06/2009 19:31:15 PM ~!~Caller ID~!~Line: 1 Number: 0708147590 Name:
16/06/2009 19:31:23 PM ~!~Caller ID~!~Line: 1 Number: 0227779977 Name:
16/06/2009 19:31:54 PM ~!~Caller ID~!~Line: 1 Number: 025020540 Name:
16/06/2009 21:01:40 PM ~!~Caller ID~!~Line: 1 Number: 0344544530 Name:
16/06/2009 21:02:45 PM ~!~Caller ID~!~Line: 1 Number: 0344544530 Name:
16/06/2009 21:06:55 PM ~!~Caller ID~!~Line: 1 Number: 022713226 Name:
16/06/2009 21:07:58 PM ~!~Caller ID~!~Line: 1 Number: 022713226 Name:
16/06/2009 21:12:12 PM ~!~Caller ID~!~Line: 1 Number: 0704497345 Name:
16/06/2009 21:12:45 PM ~!~Caller ID~!~Line: 1 Number: 0704497345 Name:
16/06/2009 21:34:14 PM ~!~Caller ID~!~Line: 1 Number: 0344544530 Name:
16/06/2009 21:35:00 PM ~!~Caller ID~!~Line: 1 Number: 0344544530 Name:
17/06/2009 13:03:46 PM ~!~Caller ID~!~Line: 1 Number: 0462705102 Name:
17/06/2009 13:16:52 PM ~!~Caller ID~!~Line: 1 Number: 0709956189 Name:
17/06/2009 13:48:19 PM ~!~Caller ID~!~Line: 1 Number: 0766277677 Name:
17/06/2009 13:50:23 PM ~!~Caller ID~!~Line: 1 Number: 0766277677 Name:
17/06/2009 13:56:44 PM ~!~Caller ID~!~Line: 1 Number: 0766277677 Name:
17/06/2009 13:57:26 PM ~!~Caller ID~!~Line: 1 Number: 0766277677 Name:
17/06/2009 14:37:11 PM ~!~Caller ID~!~Line: 1 Number: 025020540 Name:
17/06/2009 14:37:42 PM ~!~Caller ID~!~Line: 1 Number: 0766277677 Name:
17/06/2009 14:42:18 PM ~!~Caller ID~!~Line: 1 Number: 0920240000 Name:
17/06/2009 14:43:18 PM ~!~Caller ID~!~Line: 1 Number: 0920240000 Name:
17/06/2009 19:11:20 PM ~!~Caller ID~!~Line: 1 Number: 0921342915 Name:
21/06/2009 14:40:47 PM ~!~Caller ID~!~Line: 1 Number: 040133565 Name:
22/06/2009 12:58:14 PM ~!~Caller ID~!~Line: 1 Number: 0462705102 Name:
22/06/2009 13:01:07 PM ~!~Caller ID~!~Line: 1 Number: 0462705116 Name:
22/06/2009 17:30:01 PM ~!~Caller ID~!~Line: 1 Number: 0462705116 Name:
22/06/2009 19:53:26 PM ~!~Caller ID~!~Line: 1 Number: 0921342915 Name:
23/06/2009 18:34:41 PM ~!~Caller ID~!~Line: 1 Number: 0462705116 Name:
24/06/2009 13:58:16 PM ~!~Caller ID~!~Line: 1 Number: 0768881146 Name:
24/06/2009 13:58:48 PM ~!~Caller ID~!~Line: 1 Number: 021351031 Name:
24/06/2009 19:04:48 PM ~!~Caller ID~!~Line: 1 Number: 0921342915 Name:
25/06/2009 13:16:25 PM ~!~Caller ID~!~Line: 1 Number: 0462705116 Name:
25/06/2009 15:45:58 PM ~!~Caller ID~!~Line: 1 Number: 0406227565 Name:
25/06/2009 17:08:29 PM ~!~Caller ID~!~Line: 1 Number: 0462705102 Name:
25/06/2009 19:14:37 PM ~!~Caller ID~!~Line: 1 Number: 0406227565 Name:
28/06/2009 13:08:21 PM ~!~Caller ID~!~Line: 1 Number: 0921342915 Name:
29/06/2009 08:38:15 AM ~!~Caller ID~!~Line: 1 Number: 0462705116 Name:
29/06/2009 11:14:15 AM ~!~Caller ID~!~Line: 1 Number: 018389122 Name:
29/06/2009 12:12:43 PM ~!~Caller ID~!~Line: 1 Number: 099950210 Name:
30/06/2009 08:36:26 AM ~!~Caller ID~!~Line: 1 Number: 0462705116 Name:
30/06/2009 15:57:15 PM ~!~Caller ID~!~Line: 1 Number: 0462705116 Name:
30/06/2009 17:39:48 PM ~!~Caller ID~!~Line: 1 Number: 0406227565 Name:
30/06/2009 20:11:56 PM ~!~Caller ID~!~Line: 1 Number: 0406313200 Name:
Tasker Plugin / Speech Droid
Tonlof | Sweden
Here is the script that I use. Not fancy but works. Just does the number of unread messages (really all that is important to me). It is triggered by two events. The first is whenever a call ends. The second is whenever a message is read.
Code:'======================================================================================================================================= 'This script updates the unread messages device (P1) string to include a custom phone icon, update the string for the number of unread 'messages, and provide a link to phone pages if there are unread messages messages. '======================================================================================================================================= Sub Main(parm as object) dim mb mb = hsp.MBGet("1") if mb.unread_messages = 0 Then hs.SetDeviceString("P1", "<img src=images/Custom/phone.gif> No Messages", TRUE) Else hs.SetDeviceString("P1", "<a href=hspw><img src=images/Custom/phone.gif border=0 alt=Messages/></a>" & " " & mb.unread_messages, TRUE) End If End Sub
Give this a try. This should play all of your unread messages over the speaker clients. It uses the same http command as the HSP web page. It could be altered by changing the hs.speak command to only speak to certain speaker clients. HSTouch could pass this variable to the script as well. I don't currently have any messages so I'm not sure the for loop will work correctly. I will try tomorrow and edit if needed.
Code:Sub Main(parm as object) dim line 'line number dim mb 'mailbox dim vmFile 'voicmail file to play dim messages 'number of unread messages dim i 'index for message loop dim hsip 'IP address of HS server dim hsport 'port of HS server line = 1 'set line number to line 1 mb = hsp.MBGet("1") 'set mb equal to mail box 1 messages = mb.unread_messages 'set messages equal to number of unread messages i = 0 'set message playback loop index hsip = "192.168.0.101" 'set HS IP address hsport = 80 'set HS port 'if there are no unread messages, then announce no messages If messages = 0 Then hs.Speak("No unread messages.", FALSE) 'if there are unread messages, get the first message and play it (need to add rest of messages playback) Else 'play first unread message vmFile = hsp.MBFirstUnreadMessage(line,mb) hs.GetURL(hsip,"/hspw?no_page_gen=1&doaction=playspkr&playfile=" & vmFile,TRUE,hsport) messages = messages - 2 'play rest of the messages For i = 0 to messages vmFile = hsp.MBNextUnreadMessage(line,mb) hs.GetURL(hsip,"/hspw?no_page_gen=1&doaction=playspkr&playfile=" & vmFile,TRUE,hsport) Next i End If End Sub
Haven't had much time to play with it, but it did work with 1 unread message in my inbox. Im not really sure how the nextunreadmessage function works so I was planning to play with it with multiple voicemails. The url that I am using is basically how the HSPhone voicemail page works at playing a message (passes an HTTP post to HS). There is probably a way to do this with the HSP functions by getting the filenname of the next voicemail, playing that wav file on a client and then marking the message as read. This is basically a quick and dirty way to get it to work. Unfortunately, going on vacation in a couple of days so not sure I will get this working well before I leave but will definitely get this to be something functional. Also, not sure if the HST people are working integrating HSP into HS Touch. Seems like a no brainer to add this functionality.
OK, spent a tad more time on this. The following is functional. I will probably replace the http post with a function that gets the name of the next wav file, plays it over the speaker client(s) and then marks the message as read. However, I think this accomplishes the same thing.
Setup is as follows:
- Copy past the code below into a script called playunreadmessages.vb and save in your script subdirectory.
- In HS Touch, create a button and add an action when released with the following parameters.
Action Type: HomeSeer: Run a HomeSeer script with values from elements(s)
Script: playunreadmessages.vb
Script Procedure: Main
Leave the parameters blank. In the future, this can probably be setup to pass the name of the client that is calling the script so that the name can be used in the script if you like to just play the messages on that cliennt.
That's it.
Code:Sub Main(parm as object) dim line 'line number dim mb 'mailbox dim vmFile 'voicmail file to play dim messages 'number of unread messages dim i 'index for message loop dim hsip 'IP address of HS server dim hsport 'port of HS server dim speaker 'name of speaker client dim msgnum 'message number to call out line = 1 'set line number to line 1 mb = hsp.MBGet("1") 'set mb equal to mail box 1 messages = mb.unread_messages 'set messages equal to number of unread messages i = 0 'set message playback loop index hsip = "192.168.0.100" 'set HS IP address hsport = 80 'set HS port speaker = "" 'set spaker client (leave blank "" for all) msgnum = 2 'if there are no unread messages, then announce this If messages = 0 Then hs.Speak("You have " & messages & "unread messages.", FALSE, speaker) 'if there are unread messages, get the first message and play it (need to add rest of messages playback) Else 'play first unread message hs.Speak("You have " & messages & "unread messages.", TRUE, speaker) hs.Speak("Playing first message.", TRUE, speaker) vmFile = hsp.MBFirstUnreadMessage(line,mb) hs.GetURL(hsip,"/hspw?no_page_gen=1&doaction=playspkr&playfile=" & vmFile,TRUE,hsport) messages = messages - 1 'play rest of the messages For i = 1 to messages hs.Speak("Playing message " & msgnum, TRUE, speaker) vmFile = hsp.MBNextUnreadMessage(line,mb) hs.GetURL(hsip,"/hspw?no_page_gen=1&doaction=playspkr&playfile=" & vmFile,TRUE,hsport) msgnum = msgnum + 1 Next i hs.Speak("Finished playing unread messages.", FALSE, speaker) End If End Sub
As another alterative to get more functionality, create a text item. Then in the Text field put the following:
http://HOMESEER IP ADDRESS/hspw
This will bring up the HS caller ID webpage inside the text item you just created. I'm sure there is a way to get the headers out of there or just bring up the caller ID / voicemail graphic but not sure how that would be done at the moment. It works, just not pretty yet.
Originally posted by heatvent View PostAs another alterative to get more functionality, create a text item. Then in the Text field put the following:
Thanks for posting the code and for all your ideas on this subject.
I have been wondering about how reliable HSP would be for voicemail. I have used HSP quite a while for CID announcements, but I have never tried using it for voicemail.
It looks like my HS computer may have died today, so I guess I have a new project. I hope I can find a low wattage option to run HS.
Brian
Try this. I went away from using the url posts. This script will iterate through all of the registered mailboxes, announce the name of the mailbox, and read the unread mail over the speaker clients. Is that what you are looking for? Alternatively, it could be setup that HSTouch passes the name of the mailbox it wishes to be read and just reads that one mailbox.
Code:Sub Main (ByVal parms As Object) '======================================================================================================================================================================================= ' DECLARE VARIABLES '======================================================================================================================================================================================= Dim mb Dim messages Dim path Dim TotalMsgs Dim NumUnheardMsgs Dim NumHeardMsgs Dim playfile Dim i Dim NumMBs Dim x '======================================================================================================================================================================================= ' MAIN SCRIPT - GET MAILBOX DATA '======================================================================================================================================================================================= hsp.MBSort() NumMBs = hsp.MBCount() hs.WriteLog("HST Phone", "There are " & NumMbs & " total mailboxes.") path = hsp.GetAppPath & "\messages\" ' set path for messages For x = 1 To NumMBs mb = hsp.MBGet(x) ' get the mailbox passed by parms messages = mb.messages ' get the collection of messages hs.Speak("Retreiving messages for " & mb.username, True) TotalMsgs = mb.total_messages ' Total number of messages hs.WriteLog("HST Phone", "There are " & TotalMsgs & " total messages.") NumUnheardMsgs = mb.unread_messages ' Total unread messages hs.WriteLog("HST Phone", "There are " & NumUnheardMsgs & " unread messages.") NumheardMsgs = TotalMsgs - NumUnheardMsgs ' Total read messages hs.WriteLog("HST Phone", "There are " & NumheardMsgs & " read messages.") '======================================================================================================================================================================================= ' MAIN SCRIPT - PERFORM ACTIONS BASED ON HSTOUCH BUTTON PRESSED '======================================================================================================================================================================================= If NumUnheardMsgs = 0 Then hs.Speak("There are no new messages.", True) Else Select Case NumUnheardMsgs Case 1 hs.Speak("There is one new message.", True) Case Else hs.Speak("There are " & NumUnheardMsgs & "new messages.", True) End Select For i = NumheardMsgs + 1 To TotalMsgs playfile = messages(i).filename ' Get name of file to play hs.Speak("Message " & i & " Sent " & hsp.MBMessageDate(playfile) & " at " & hsp.MBMessageTime(playfile) & ", From " & hsp.MBMessageName(playfile), True) hs.Speak(Path & playfile, TRUE) hsp.MBMarkRead(playfile) ' Mark playfile as read NumUnheardMsgs = mb.unread_messages ' Reset the number of unheard messages Next hs.Speak("End of new messages for " & mb.username, True) End If Next End Sub
Firstly my apologies for the delay in my reply, I have been ill so had to put this on the back burner.
Thank you heatvent that script is great, as a result I now use a combination of the original script which I modified to look in only one of the mailboxes and have it run 3 times (once for each mailbox) and use your script untouched to cycle through when a button is pressed in HSTouch, having the script only play the mailbox selected would be the next step but is not of great urgency.
Again thank you for your help
