NetCAM plugin: how to authenticate to a camera to capture snapshot using POST
    i have a few dahua cameras with newer fw and they don't support the username/pswd as part of the url via a GET
    the username/pswd needs to be "POST"ed
    any ideas of how to do this?
    Mark
    HS3 Pro 4.2.19.5
    this is the only way i have seen it done.
    PHP Code:
    http://username:password@192.168.1.167/
    did you ever work it out?
    HS3 Pro on Windows 8 64bit
    53 Z-wave nodes(46 devices, 7 remotes), 15 DS10a's, 10 ms16a's, 9 Oregon Sensors, W800, RFXCOMtrx433, Way2Call, 3 HSTouch Clients, 2xRussound CAS44, Global Cache GC100-12,10 Rollertrol blinds(+ zwave) ,3 Squeezebox Radios and 1 Squeezebox Boom,DMX Arduino via ethernet,Rain8Net,3x Echo Dot's
    Check out my electronics blog here:
    https://www.facebook.com/RaptorsIrrationalInventions
      PHP Code:
      Your method works when using Chrome, but not IE. It also does not work with HS3...i get an error. My guess is HS3 uses the IE class to do this.
      Posting back to plugin web page NetCam_View: Object reference not set to an instance of an object.-> at System.Runtime.Remoting.Messaging.LogicalCallContext.Propaga teIncomingHeadersToCallContext(IMessage msg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Mess ageData& msgData, Int32 type) at HomeSeerAPI.IPlugInAPI.PostBackProc(String page, String data, String user, Int32 userRights) at Scheduler.proxyPage.postBackProc(StateObject& state, String Data)
      Mark
      HS3 Pro 4.2.19.5
        so i found the following registry tweak that allows the above url to work some of the time!
        FEATURE_HTTP_USERNAME_PASSWORD_DISABLE (google to see how to implement)
        there are two locations: 1 for 32 bit IE, and a second for the 64 bit IE
        Note: i haven't gotten this to work on Server 2012 which is where HS3 is installed.
        Mark
        HS3 Pro 4.2.19.5
          http://username:password@192.168.1.2.../snapshot.cgi?
          Apr-19 9:51:20 AM Error Getting web page from plugin page NetCam_Config:Object reference not set to an instance of an object.
          Apr-19 9:51:15 AM Warning Plugin NetCAM is not responding but it is still running, not restarting yet.
          Apr-19 9:51:11 AM Error Posting back to plugin web page NetCam_View: Object reference not set to an instance of an object.-> at System.Runtime.Remoting.Messaging.LogicalCallContext.Propaga teIncomingHeadersToCallContext(IMessage msg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Mess ageData& msgData, Int32 type) at HomeSeerAPI.IPlugInAPI.PostBackProc(String page, String data, String user, Int32 userRights) at Scheduler.proxyPage.postBackProc(StateObject& state, String Data)
          Mark
          Mark
          HS3 Pro 4.2.19.5
            i ended up installing blue iris then using its webserver to let homeseer access it.
              thanks.
              i considered blue iris but decided on Synology Survellience Station. i wanted to avoid the additional load on my server. i did figure out my snapshot issue with the Dahua cameras with the latest firmware v2.4x.
              http://192.168.1.22/onvifsnapshot/media_service/snapshot?channel=1&subtype=0
              there is no authentication required but my cameras are not exposed to the internet so no worries
              Mark
              HS3 Pro 4.2.19.5
                thanks.
                Was looking Surveillance Station as well vs BI - is there a way to trigger motion alerts in HS from Surveillance Station? So if there is motion on a camera, turn on a light, etc. The plugin doesn’t look like its active anymore. Or do you do this directly off of your cameras?
                  I tried the SS plugin when it was in beta and wasn't happy with the results...too slow between SS and HS. I have an actual motion sensor along side every outside camera to trigger lights (i use insteon)
                  Mark
                  HS3 Pro 4.2.19.5
                    Helpful - thank you. Insteon for motion sensors too?
                      yes, insteon light switches and motion sensors
                      Mark
                      HS3 Pro 4.2.19.5
