Go Back   HomeSeer Message Board > Camera Plug-ins > Camera Discussion > HomeSeer NetCam Plug-in
HomeSeer NetCam Plug-in The NetCam plugin provides access to network based cameras.
Old April 4th, 2016, 08:19 AM
fvhemert fvhemert is offline
Seer Deluxe
Script to e-mail NetCam pictures
Migrating from HS2 to HS3.
I used to have a script in HS2 that sends a picture from the front door camera to a predefined e-mail addres when somebody rings the doorbel.
When trying to use the script in HS3 it fails on pi = hs.Plugin("Netcam")with
Running script C:\Program Files (x86)\HomeSeer HS3\scripts\E_mail pictures.vb :Exception has been thrown by the target of an invocation.Public member 'Plugin' on type 'hsapplication' not found
I believe this is caused because HS3 deals with plugins in a different way.
Is a new sample script available to send NetCam pictures?
Old April 4th, 2016, 09:48 AM
mhn mhn is offline
Seer Master
I just use events for that?
Regards
Morten
Old April 4th, 2016, 10:55 AM
Seer Deluxe
Taking the pictures, no problem but how do i send the 3rd picture out of 5 using an event?
Old April 4th, 2016, 01:06 PM
mhn mhn is offline
Seer Master
I just send CurrentImage.jpg. Works fine with two cams. But in theory I can get in trouble. :-)
Old April 5th, 2016, 02:49 AM
Seer Deluxe
Yes, current image works but I liked the flexibility of choosing which foto to send out of a range of 5.
Still trying to understand how to modify the script below to get it to work in
HS3
Sub Main(Optional ByVal pParms As String = "")
	Dim pi As Object
	dim time
	time = timevalue(now)
	Dim files As Collection = pi.getimages("XXXXXX")
	If files.Count >= 2 Then
		Dim latestImage As Integer = 2
		Dim strFileName As String = files(latestImage).Replace("_thmb","")
		hs.WriteLog("Info", "File to send: " & strFileName)
		hs.SendEmail("X@X.X", "X@X.X", "Deurbel "&time, "Voordeur", strFileName)
		hs.SetDeviceString ("Z99", strFileName, True)
	End If
End Sub
I believe the answer can be found at https://homeseer.com/support/homeseer..._functions.htm but I have no idea how to apply this to the NetCam plug in.
Old June 30th, 2016, 04:08 AM
charlesmbell's Avatar
charlesmbell charlesmbell is offline
Seer Deluxe
Quote:
Still trying to understand how to modify the script below to get it to work in .
Did you ever find a way to ge this to work in HS3. I also just upgraded and used to email 3rd out of 5 type setup like you on HS2. But cannot figure it out on HS3.
UPDATE:
sort of a workaround, but I basically just captured the correct amount of pics then used the latest.jpg. I cannot do more than one event at a time, but as long as I don't have multiple triggers, it works ok.
HTML code is Off
Netcam-mailing pictures WfromL HS3 Plug-In Development 6 June 12th, 2016 11:47 PM
Jun00 Mail Script ~Ghost~ HomeSeer General Discussion Area 2 June 3rd, 2015 09:18 PM
NetCam PlugIn - No Pictures lzhenry HS3 / HS3PRO Discussion 0 February 16th, 2015 10:39 PM
e mail script afmiller Jon00's plugins and scripts 1 December 11th, 2011 09:52 AM
how to show pictures from netcam plugin. ralphie Designer 1 July 24th, 2011 02:26 PM
