Feature Requests for the Mark Sandler Insteon PLM Plug-In
    Mark,
    You ever hear anything back from them?
    Steven G
      Originally posted by steveng View Post
      Mark,
      Steven G
      no. something must be going on at sh, i usually get a response by now
      Mark
      HS3 Pro 4.2.19.5
        Mark
        Just checking in on the outlets.
        Steven G
          Steven,
          turns out the device is working as designed. (but not as expected)
          not sure what the work-around is.
          Mark
          HS3 Pro 4.2.19.5
            Mark,
            That is a bummer, such potential for the product.
            Thanks again for checking into it.
            Steven G
              Mark,
              Steven G
              yah, I'm wondering if they will change this in future versions. apparently the dimmer version of the outletlinc has this feature.
              Mark
              HS3 Pro 4.2.19.5
                Support for Insteon Heat Pump Thermostat
                I just purchased the model 2732-242. Does your Insteon Plug-in currently support it? If now when do you anticipate it being added to your plug-in?
                  no, thermostats are supported via the a separate plugin. see the following forum
                  http://board.homeseer.com/forumdisplay.php?f=1183
                  Mark
                  HS3 Pro 4.2.19.5
                    Insteon has just released a new alert module - 2867-222. It is currently not supported.
                      i will add support once i get a unit and the dev notes
                      Mark
                      HS3 Pro 4.2.19.5
                        Hi Mark,
                        I'm not sure if this has been asked for previously... but I am just starting to program groups and thought it would save me a few clicks if there was a "copy selected group" button between add and delete.
                        Ultimately, it would create a new group that has the same devices selected with same parameters, but probably default the optional controller to "none".
                        I saw someone else had suggested an option to capture current dim levels - I +1 that too
                        thanks,
                        Dave
                          Originally posted by dhalsall View Post
                          Hi Mark,
                          thanks,
                          Dave
                          i've added a 'copy selected group' feature. look for it in the next version i post.
                          Mark
                          HS3 Pro 4.2.19.5
                            Mark Devices Offline
                            Just the ability to configure a device offline, such that it would not be polled. This would be very handy for my Christmas Light devices which spend 10.5 months/yr in my drawer.
                              configuring a device offline, isn't possible.
                              there is an event action that allows you to change the polling freq. create events to change the freq when you install or pull a device.
                              Mark
                              HS3 Pro 4.2.19.5
                                Mark, I think what he means is having the ability to temporarily disable some devices so they can be unplugged without causing the plugin to give errors that they can not be contacted. This would be great for devices that are only used for Christmas lights. Currently I have to leave all my Christmas-only devices plugged in all year so the plugin doesn't keep logging them as failing after 5 tries.
