Originally posted by Moskus
View Post
Qubino z-wave - Working!
Have you associated group 4 to HS?HSPro 3.0.0.458, Z-NET with Z-wave plugin 3.0.1.190, RFXCOM + 2x RFXtrx433E, HSTouch, Squeezebox plugin, iTach IP/WF2IR & GC-100-6 with UltraGCIR, BLDenon, NetcamStudio, Jon00s Webpage builder, Harmony Hub plugin, SCSIP (with FreePBX), Arduino plugin, IFTTT, Pushalot plugin, Device History plugin.
What happens if you poll the device, then?HSPro 3.0.0.458, Z-NET with Z-wave plugin 3.0.1.190, RFXCOM + 2x RFXtrx433E, HSTouch, Squeezebox plugin, iTach IP/WF2IR & GC-100-6 with UltraGCIR, BLDenon, NetcamStudio, Jon00s Webpage builder, Harmony Hub plugin, SCSIP (with FreePBX), Arduino plugin, IFTTT, Pushalot plugin, Device History plugin.
Im having some problems with these dimmers and the control of them. Unlike fibaro they dont have sliders for control. If i try adjust it for slider and use them in HSTouch i can't adjust them from 0-100% where 0% would turn them off. How should i proceed with this?
EDIT:
It might seem that first time you add them they are just wrong after deleting the control part and then rescan device i get the regular dimming with on/off and dimming controlls not all the other weird uncontrollable stuff. But still i feel the control in HStouch it not good when using a slider.
EDIT2:
Im wondering cause when i have a slider and i drag it all the way up the light does not go ON(100%), i need to drag it almost to top to get around 98% or so. But with the Fibaro dimmers i have i can drag to top and it will get to ON. How can i get that when slider is dragged to the top i goes 100 on?Last edited by U5tabil; March 25, 2015, 04:25 PM.Certified installer for HomeSeer, Control4, KNX and Eaton/xComfort
Originally posted by U5tabil View PostEDIT2:
Im wondering cause when i have a slider and i drag it all the way up the light does not go ON(100%), i need to drag it almost to top to get around 98% or so. But with the Fibaro dimmers i have i can drag to top and it will get to ON. How can i get that when slider is dragged to the top i goes 100 on?HSPro 3.0.0.458, Z-NET with Z-wave plugin 3.0.1.190, RFXCOM + 2x RFXtrx433E, HSTouch, Squeezebox plugin, iTach IP/WF2IR & GC-100-6 with UltraGCIR, BLDenon, NetcamStudio, Jon00s Webpage builder, Harmony Hub plugin, SCSIP (with FreePBX), Arduino plugin, IFTTT, Pushalot plugin, Device History plugin.
The slider on the web page should behave this way. Meaning: It only uses dim values, from 1% to 98%. The Off button turns it off, and the On button sets it to On ("99%").
If the device is set to "Is Dimmable" then a HStouch slider should be able to use the whole value span, that is from 0 ("Off") via all the dim values (1 to 98) and stop at 99 ("On").HSPro 3.0.0.458, Z-NET with Z-wave plugin 3.0.1.190, RFXCOM + 2x RFXtrx433E, HSTouch, Squeezebox plugin, iTach IP/WF2IR & GC-100-6 with UltraGCIR, BLDenon, NetcamStudio, Jon00s Webpage builder, Harmony Hub plugin, SCSIP (with FreePBX), Arduino plugin, IFTTT, Pushalot plugin, Device History plugin.
Originally posted by Moskus View PostThe slider on the web page should behave this way. Meaning: It only uses dim values, from 1% to 98%. The Off button turns it off, and the On button sets it to On ("99%").
If the device is set to "Is Dimmable" then a HStouch slider should be able to use the whole value span, that is from 0 ("Off") via all the dim values (1 to 98) and stop at 99 ("On").Certified installer for HomeSeer, Control4, KNX and Eaton/xComfort
Value 255 for Z-wave dimmers are usually named "On Last Level". If you dim the light to 50% and turn it off, using "On Last Level" will dim the light back to 50%, not 100%.
These are the "correct" values and labels, taken from a Fibaro dimmer, but other dimmers are equal.
Guys
I am trying to use these dimmers, I have just about got the dimmer to work (by deleting the created device which appears to think it is a shutter) and have LED's connected to it which appear to dim OKish (a bit jumpy on slow fades but could be a parameter issue).
Does anyone have the I2/I3 inputs working? They both show as 'Sensor Binary Reserved 1' and 'Sensor Binary Reserved 2' in HS and I have connected switches to them. I have associated Group 2 and Group 3 with HomeSeer (which I think is correct) as per the documentation. When I switch the switches the root device updates it's last change column but the child devices do not update at all and just stay at off. I have deleted these child devices and pressed rescan but no change - they simple stay off. HS clearly sees some form of communication to it to update the last change column but seemingly not getting to the device itself. I have tried polling the unit and polling does not pick it up either. In the HS log I get;
May-02 23:34:44 Z-Wave Device: Z-Wave Goap Switch Multilevel Node 3 Root Set to OFF
May-02 23:34:39 Z-Wave Device: Z-Wave Goap Switch Multilevel Node 3 Root Set to ON
May-02 23:34:35 Z-Wave Device: Z-Wave Goap Switch Multilevel Node 3 Root Set to OFF
May-02 23:34:23 Z-Wave Device: Z-Wave Goap Switch Multilevel Node 3 Root Set to ON
So it appears just be trying to turn the root device off and on rather than the child devices.
The product is certified as per http://products.z-wavealliance.org/products/1231
Anyone any ideas what I might be missing? Thanks...
