Go Back   HomeSeer Message Board > Camera Plug-ins > Camera Discussion > HomeSeer NetCam Plug-in
HomeSeer NetCam Plug-in The NetCam plugin provides access to network based cameras.
Old March 7th, 2015, 09:37 AM
jplauring jplauring is offline
how to connect security camera dvr system to homeseer?
I have an independent security camera system all tied into a dvr that is connected to my home network , any easy way to get that video output into homeseer so i can see all my devices and cameras on homeseer remotely?
Old March 7th, 2015, 11:40 AM
clay2young's Avatar
clay2young clay2young is offline
Arrow I Integrate Mine with Blue Iris
Don't know what DVR/camera system you use.
I have all my IP cams going to a dedicated PC with Blue Iris.
I have the Blue Iris plugin on my HS3 PC and trigger recording from within HS3.
I monitor it all with the Blue Iris iPhone and iPad App.
Alerts and Notification can be sent from both BI and HS3.
Benefits
Motion triggering from HSTs HSM200 much better than either BI or the individual camss motion detection.
I can trigger recordings and image alerts by door sensors and door lock changes, not just motion, also by the change in status of any HS3 device.
2017-04-01: Shuttle XH81V Mini PC, dual RS232. Processor:Intel Core i7-477O5 - 3.1 GHz, 5.0 GT/s, 8MB. RAM: 16GB DDR3-1600MHz. Hard Drives:Two 240GB Internal Solid state disks (SSD). External 1T USB 3 drive. Dedicated for HomeSeer. (backup for other apps)
OS:Windows 10 Pro, HS3 3.0.0.315 with UACPass. Currently mostly Z-Wave Devices (137 nodes) 90%+ LED, Plugin 3.0.1.25, Z-NET 1.0.13. HSTouch .68, RFXCOM with 5 Sensors, MyQ plug-in, BlueIris, Pushover, Restart, Edge Browser.
Old April 2nd, 2015, 04:32 PM
DigitalMatrix DigitalMatrix is offline
I've wondered the same thing.
I have a Swan DVR which uses proprietary software for viewing.
In the past I've used an IPVideo 9100a and split the camera video off to the 9100a. I'm just getting my HS3 setup so I haven't got to the camera piece yet but it is something I want to do.
Let me know if you come up with something.
Jay
HS3 3.0.0.152
Devices: Napco Gem-9600 | Intsteon 2413U | HA7Net
Plugins: HSTouch | Insteon (mnsandler) | Napco Gemini | Random | Ultra1Wire3 | weatherXML
PC: Windows 8.1 Pro 64bit, i3-4130 4.3GHz, 16GB RAM
HS2 R.I.P (2004-2015) - Burned up power supply after 11 years.
Old May 4th, 2015, 07:51 AM
hanissusa
Guest
Posts: n/a
HIKVISION
Thinking of purchasing HIKVISION IP 3mp cameras and just wondering which standalone NDVR would you recommend to directly connect to Homeseer controller with easy to install plugin ?
Old May 4th, 2015, 12:10 PM
wposner's Avatar
wposner wposner is offline
I have HikVision cameras around my house. Use a HikVision NVR. It's plug n play and will work with your HS setup.
Old May 4th, 2015, 12:50 PM
TomTom's Avatar
TomTom TomTom is offline
Are these ip cameras?
Tom
Tom
Old May 4th, 2015, 01:16 PM
LeoS LeoS is offline
I've had good experience with HikVision installation. They sell very reasonably priced DVR with 8 POE ports and it's pretty much plug and play if you let the DVR manage its own network.
I also use Mobotix cameras. While they're priced higher, they have loads of sensors and functionalities in it that can be used for home automation:
- Insane motion detection flexibility
- Video analytics (analyze direction of object motion, generate heatmap)
- Light sensor
- thermometer
- sound detection
- SIP client AND server
- the camera has event logic and can send IP commands to HomeSeer based on the sensor triggers)
- (optional, USB to serial, signal I/O)
- contacts for door control, lights, etc
- some models have PIR sensor
- the Q24/25 model is hemispheric (360), it can most likely replace the function of 2 or more cameras
HW: HS3 w/ Win8.1 on ASRock C2550d4i. Digi AnywhereUSB, Hubport, Edgeport, UZB, Z-trollers, PLCBUS, SONOS, GC-100, iTach IP2SL, WF2IR, IP2IR, RFXtrx433, Harmony Hubs, Hue, Ademco Vista 128BP, NetAtmo, NetAtmo Welcome
Google Search for HomeSeer Forum
Old May 4th, 2015, 07:05 PM
wposner's Avatar
Tom
Yep...All IP dome 3MP cameras using the POE capabilities from the HikVision NVR.
Old March 5th, 2017, 12:12 PM
Sheriff Sheriff is offline
This is an old thread, but I am wondering the same thing. The thread started with "Can you connect a standalone DVR/NVR system to Homeseer?". I never saw a clear answer; does anyone know? I understand the Blue Iris route, but I already have a nice NVSM 7000 with 8 POE cameras on it and would rather not start over.
HS3Pro on Windows 10
One install with 2 Ethernet Z-nets
2nd install with 1 Zstick
300 devices, 250 events, 8 scripts
5 CT-100 tstats
Serial IT-100 interface to DSC Panel with 8 wired zones
18 Fortrezz water sensors & two valve controls
Serial Rain8Net Pro with 8 zones
Homeseer as security system rsuarez HomeSeer General Discussion Area 18 December 19th, 2012 10:59 AM
connect camera's to homeseer Jaco HomeSeer General Discussion Area 3 October 19th, 2008 07:28 AM
How to connect security system to HS herbus Script & Plug-In Development 1 October 6th, 2008 07:02 PM
Homeseer and Security System cgofish23 HomeSeer General Discussion Area 15 October 24th, 2005 10:50 PM
O/T: Security System with HomeSeer? mcouture HomeSeer General Discussion Area 2 August 21st, 2005 01:58 PM
