Go Back   HomeSeer Message Board > Camera Plug-ins > Camera Discussion > HomeSeer NetCam Plug-in
HomeSeer NetCam Plug-in The NetCam plugin provides access to network based cameras.
Old August 23rd, 2017, 06:35 AM
nl_user nl_user is offline
Seer Plus
How to get a snapshot from a Y-cam cube HD1080 camera
I try to add a Y-cam cube HD1080 camera to my system.
When accessing the snapshot - url directly in my browser I get the snapshot instantly shown.
But, when having the url added in the NetCam config, it just does not grab a picture? So what's wrong here or Am I missing some part?
This is the url I added in the NetCam config (user and pwd are hidden)
http://192.168.0.11:80/snapshot.jpg?user=name&pwd=**********
 and for a second camera
http://192.168.0.12:83/snapshot.jpg?user=name&pwd=**********
Any advice on this? Thanks.
Old August 24th, 2017, 01:31 AM
Seer Plus
Any ideas on this? Would be nice if I get this working.
Thanks W.
Old August 25th, 2017, 09:58 PM
Pete's Avatar
Pete Pete is offline
I have not utilized Netcam in a very long time. (Homeseer 2 early days).
Try the same without the username and password.
Have a look here:
Y-Cam Black and HD Bullet
Try this:
hxxp://admin:admin@192.168.0.11/snapshot.jpg?user=admin&pwd=admin&strm=0
or
Note that just about every new camera has multiple streams (from HD to SD resolutions).
Here utilize both typically SD for a multiple camera view and HD for a single camera view in Zoneminder.
The higher the pixel resolution the larger the JPG will be.
Black and white or grey pictures at night utilize less than a color picture in daylight.
Old December 28th, 2017, 09:27 AM
Seer Plus
Thanks for your advise on this. I still can not get a snapshot taken by Netcam.
The problem is, if I have an Url like yours or any other format. The "Camera page" is opened and a login-screen is popping up! Only after providing a user and password in that inlog-screen the snapshot is taken. So apparently when executing through Netcam the "inlog-screen" is also opened (virtual) and is not filled and nothing will be executed?
So how to pass through the "virtual" inlog-screen than?
See image in next post:
Old December 28th, 2017, 09:32 AM
Seer Plus
Old December 30th, 2017, 04:33 AM
Seer Plus
Any thoughts on this? Still can not get it to work with these cams! Thanks.
Old December 31st, 2017, 03:00 PM
Pete's Avatar
Here continue to utilize Zoneminder for my CCTV.
Googled
Zoneminder Y-Cam and see this:
Zoneminder Y-Cam
Just a guess here ...using info...
Remote Protocol: HTTP
Remote Method: Simple
Remote Host Name: user:pass@ip_of_camera
Remote Host Port: 80
Remote Host path: /stream.jpg
Target Colorspace: 24 bit colour
Capture Width: 640 (1280 for 720p Bullet)
Capture Height: 480 (720 for 720p Bullet)
so it would be something like:
hxxp://user:pass@ip_of_camera/stream.jpg
for a snap shot?
You can check on the size of the image using Firefox and right clicking on properties of image.
NOTE: this is different from what I found above and posted in #3 above (I do not have one of these cameras)
It appears to be stream.jpg versus snapshot.jpg.
Keep trying using a browser link to the JPG. Once you have the browser link working then Netcam should not be an issue.
PM if you want me to test this from across the big pond.
1 - create a test username / password on your camera
2 - open up port 80 to your camera with your firewall.
3 - give me your internet IP address
and will test over here near Chicago.
Old January 1st, 2018, 09:17 AM
Seer Plus
Great this seems to work for me Thanks a lot!
admin:admin_passwd@192.168.0.11/snapshot.jpg
Tags
netcam, snapshot, url
Event to take a snapshot from a camera ? mikee123 HS3 Event Clinic 10 June 8th, 2016 04:31 PM
[NetCAM] Take snapshot from camera with name xxxx_latest.jpg raymonvdm HomeSeer NetCam Plug-in 8 May 6th, 2016 10:17 AM
how to take a camera snapshot that doesn't support the snapshot username/pswd in URL mnsandler UltraNetCam HSPI 0 April 14th, 2016 12:57 PM
How To Display Latests Snapshot For Network Camera Ultrajones UltraNetCam HSPI 1 December 24th, 2014 12:01 PM
remote path to camera snapshot connoleg HSTouch™ 2 March 31st, 2009 02:25 PM
