Generated chart filename
    Hi
    I am using an event to create a chart but don't know what the filename is. From the device history chart page I can get to a chart which is called something like this:
    but these names seem to change. Can I set the name so it's always the same when generated from an event? (for use in HSTouch)
    Also, where can I get the documentation for this excellent plug-in?
    Robert
    Originally posted by rjm2803 View Post
    Hi
    Robert
      Thanks that helps. But I still can't find the documentation.
      I'm running Homeseer on a Hometroller SEL. I can log into the device and can see a folder called homeseer which has a Documents folder but this is empty. I'm not sure where things are stored on it.
      Can you point me in the right direction or else post a link to a copy of the documentation please?
      Robert
        Robert
        Here's the doc - I keep this online version updated with each release:
        https://home.steveandkristie.com/skw...er%20Guide.pdf
        I'm not sure why it's not being laid down properly with the install of the plugin, but will test that before I release the next version.
