BLStat beta
    #46
    Originally posted by Blade View Post
    Their page seems to work but the call I make is not returning correctly.
    AH ha! Ok, thank you. I thought I was doing something wrong. Thanks, Bob.
    What do you mean by it still does not return the plug link if disabled and reenabled?
    Well, on the top of the WebGui, you see all the blue and gold buttons. The gold buttons are where you plugin links go. When you install the plug for the first time, it puts a new LINK button to BLSTAT at the top of the Setup Page. When you disable the plug in the interfaces page, the BLStat button gets removed but, if you re-enable it, your button does get added again to the links section.
    A similar thing happened when I installed your pllug, it removed the HS Zwave thermostate link button. I had to go in and manually put it back in.
    Transitioning to HS3Pro .298 - WinXPEmbedded
      #47
      I just disabled it here and reenabled it and the link showed here.
      Cheers,
      Bob
        #48
        Very odd....
          #49
          I posted a new build with the ability to reset the filter date from the thermostats page.
          You can also trigger on the filter date due. See the options page for the trigger. You can run an event, execute a script command or a script file.
          Cheers,
          Bob
            #50
            Very cool!
            Thank you forvadding those features!
            Btw, I installed a few more of your plugs and the did not their links to the top bar eiher.
              #51
              Post a screenshot of what you are referring to.
              Maybe I am not thinking of the same thing.
              Cheers,
              Bob
                #52
                See the orange link sections below? It is the same place where you would find the "Link Editor" button. I installed BLOccupy and there is no orange button for me. The only way I can access the setup page for that plug is through the BLUE plugins button at the very top.
                  #53
                  I have install your lastest beta version of BLstat.
                  Blstat and all your other plugin show up ok on my menu Bar.
                  Thank you
                  Bigmack48
                    #54
                    Thank you
                    Bigmack48
                    Man!
                    I wonder what can be going on with mine! FUBAR!
                      #55
                      Ok, found out what happened with the links. It was a setting thing. If you have a Blue "Plugins" button on top, you will NOT get the Orange ones unless you add them yourself.
                      Blade, on the Stat plug, the status return from the devices added by your plug have a 6-10 second delay before reporting status.
                      The default HS plug is <2 second.
                      This is in Designer. The web gui seems to be fine.
                        #56
                        How do you add the links in yourself?
                          #57
                          Using the links editor plug-in script. It is a freebie in the Updater Page.
                            #58
                            What is your polling set to?
                            The reason the HS plugin updates faster is because they have a direct API connection with Z-Wave. I am using their API calls.
                            Cheers,
                            Bob
                              #59
                              Ah, I see....
                              I have it set to poll 60 seconds.
                                #60
                                Mine is set to poll at 30 seconds in the plugin
                                Cheers,
                                Bob
