Deleted devices doesnt go away
You can stop the plugin, select the devices in HS3 "device list" and delete them then start the plugin. That will remove everything and there should be no devices on the plugin config interface.Author of Highpeak Plugins | SMS-Gateway Plugin | Blue Iris Plugin | Paradox (Beta) Plugin | Modbus Plugin | Yamaha Plugin
Ok - that worked!
That removed all the items on the plugin-config-page.
If I add a master, it takes the default name, and the communication works.
I can add devices, and they all work.
If I try to change the polling interval to 1 second, I get disconnected, and the gateway device changes name to "master", and all devices stop working!
See attached pictures.
Can you help me?
I want to change the polling
This looks like an localization issue where a time format using a '.' Delimiter is not parsed as a time value and then the wheels come off. What regional setting are you using? Is there any chance you can switch to US or UK locale and test again to confirm this?
Sent from my iPad using TapatalkAuthor of Highpeak Plugins | SMS-Gateway Plugin | Blue Iris Plugin | Paradox (Beta) Plugin | Modbus Plugin | Yamaha Plugin
