Hi everyone/Don,
Quick question. I have Caseta right now everywhere in my home and it works fine. I really want nice keypads though like the Radio RA2 ones but switching fully to Radio RA2 doesn't really make sense as I learned I can't use Caseta dimmers with it, so wouldn't be cost effective to replace it all.
I have the Caseta plugin for HS3, and noticed there's this Radio RA2 one. Does the keypads for Radio RA2 work similar to Caseta Pico's, in that in the HS3 plugin I could do my own scenes or actions? So for example, have a keypad button called "Pathway" but when pressing that, it triggers a HS3 event that turns on a Hue and Z-Wave light? So basically not really use Radio RA2 programming but more just HS3 to run everything on it.
If so, what is the minimum I would require strictly to just use Radio RA2 keypads with HS3? I assume I'd need the normal Main Repeater? Then do I also need the Connect Bridge or anything? Lastly, would Radio RA2 make the most sense for this or would HomeWorks QS work also? Thanks!
