Can Z-NET be used with HS2?
Does Z-NET work wih HS2?
Not with ZNet but it looks to almost work with my POE remote in the attic RPi-ZWave GPIO configuration testing a bit here...ZNet communicates via the same serial to ethernet interface so you would see similar...
2/14/2018 8:04:41 AM Z-Wave :- :- :- :- :- :- :- :- Initializing Z-Wave Interface -: -: -: -: -: -: -: -:
2/14/2018 8:04:41 AM Z-Wave Initializing Z-Wave Interface on Ethernet port: 2001 IP Address: 192.168.244.169
2/14/2018 8:04:41 AM Z-Wave Z-Wave Ethernet at IP 192.168.244.169, connected to interface ok.
2/14/2018 8:04:41 AM Z-Wave Getting node information from controller...
2/14/2018 8:04:43 AM Z-Wave Z-Wave Serial API version: 5
2/14/2018 8:04:43 AM Z-Wave Z-Wave interface node ID: 1, Home ID: C24F18F8
2/14/2018 8:04:43 AM Z-Wave Found 25 Z-Wave nodes in interface node ID 1
2/14/2018 8:04:43 AM Z-Wave Controller Manufacturer: Error, Unknown, ID=0x1, Type=0x400
2/14/2018 8:04:43 AM Z-Wave Controller firmware version: 5.0
2/14/2018 8:04:44 AM Z-Wave Warning This Z-Wave PC Controller Library Version is: Z-Wave 3.99 (Unknown ZDK Version)
2/14/2018 8:04:44 AM Z-Wave This Z-Wave PC Controller is Type: ZW_LIB_CONTROLLER_STATIC
2/14/2018 8:04:44 AM Z-Wave Starting Z-Wave Polling...
2/14/2018 8:04:44 AM Z-Wave Z-Wave network key has been updated and saved.
2/14/2018 8:04:44 AM Z-Wave Z-Wave services for communications to nodes utilizing the SECURITY COMMAND CLASS were successfully started.
NOTE: thinking current firmware (ZDK version) is now at 5.X and I have not updated my controller here. I am guessing here that there will not be any updates to the Homeseer 2 Z-Wave drivers so it would not be worth any efforts for you to utilize HS2 with current ZWave controllers. In Homeseer 2 the ZWave drivers are built in to the core and you will not be able to update the HS2 core of last version released.
I have a test Z-Wave network running here...the old HS2 plugin can read the Z-Wave nodes....
Loading network information from your Z-Wave interface... Done.
Synchronizing network information against HomeSeer devices...
The Z-Wave network has 24 nodes.
Found node 2. Retrieving class and manufacturer information from the node.
Updating the status for newly added device: Z-Wave Interface Z-Wave Binary Switch
and the list of retrieving nodes completes here....
Found node 37. Retrieving class and manufacturer information from the node.
Updating the status for newly added device: Z-Wave Interface Z-Wave Static Controller 37
Finished with Z-Wave device synchronization.
And it does create devices...here is the top of the list...
[ATTACH]66657[/ATTACH]
Disabled it and re-enabled HS3 ZWave with no issues.
Feb-14 8:19:32 AM Z-Wave Initializing Z-Wave interface ZWaveMe (Ethernet Interface) at 192.168.244.169, port 2001
Feb-14 8:19:32 AM Z-Wave ZWaveMe: ----------------------------------------------------------------------
Feb-14 8:19:32 AM Z-Wave ZWaveMe: The Z-Wave Command Execution Thread was Started or Restarted.
Feb-14 8:19:32 AM Z-Wave ZWaveMe: Z-Wave Ethernet at IP 192.168.244.169, connected to interface ok.
Feb-14 8:19:32 AM Z-Wave ZWaveMe: The Z-Wave API Execution Thread was Started or Restarted.
Feb-14 8:19:32 AM Z-Wave ZWaveMe: Getting node information from controller...
Feb-14 8:19:34 AM Z-Wave ZWaveMe: Controller Manufacturer: Telsey, ID=0x1, Type=0x4
Feb-14 8:19:34 AM Z-Wave ZWaveMe: Controller firmware version: 5.0
Feb-14 8:19:35 AM Z-Wave ZWaveMe: Z-Wave services for the SECURITY COMMAND CLASS were successfully started.
Feb-14 8:19:35 AM Z-Wave ZWaveMe: Z-Wave interface node ID: 1, Home ID: C24F18F8Last edited by Pete; February 14, 2018, 01:55 PM.- Pete
