Restoring Previous Date of Homeseer Configuration?
    Is it possible to restore the homeseer system to a previous date and if so how is this accomplished?
    Does homeseer automatically save homeseer configuration every so many days or a specific time interval?
    Somehow several of my plug-ins disappeared and not sure the easiest way to resolve this issue?
    Thanks for the help.....Rick
    Last edited by Rick Bonari; June 4, 2018, 02:47 AM. Reason: Additional Information
    I don't know if HS has its own backup, I'm still newbie here.
    For myself I run it in a VM, and be doing major change I manually take a snapshot before in case I want to go back.
    Sent from my Nexus 6P using Tapatalk
      HomeSeer creates a backup each time it is started. There are up to 10 copies retained. They are in the \data directory and have the same name as your data file with “_X” appended to the name, with “X” being a number from 1-10. You will need to look at the files datestamp to determine which is the newest.
      Since a backup is only created at startup, they can get quite old. I recommend a backup plug-in or software package too cheduled backups. I use BLBackup for HomeSeer backups and Macirum Reflect for system backups. HomeSeer and the system backed up daily.
        I also use and recommend the free plugin "BLBACKUP".
          I'm reading description of blbackup and it look like Windows oriented.
          Does it work for a Linux installation?
