OK, I'll try and add something over the next day or two.
Jon00 Virtual device graphing utility
V1.01 released!
Version 1.01 is now available.
The only change in this version is the ability to monitor the device status of a device to provide metrics for on,off and dim values:
On: 100
Off: 0
Dim: Percentage value (0-100)
(0 to 100 being the value given to the graph)
You could now for example, create 2 graphs; one for temperature and one to show when the HVAC is operating in a room.Last edited by jon00; January 10, 2009, 07:20 AM.
Hello Jon,
Thanks for another great plugin.
I have installed version 1.01
I tried to make a graph for the amount off toilet visits
But the only thing i see is number 17 in the graph
I use a ds10 sensor with code:_17
I have made a event as discript in the manual
I trigger only when the toilet is flusht
The graphics from my temp sensors working great.
http://www.esschenk.dyndns.org/BUILDPAGE.ASh?VAL=Qv
[Graph3]
Housecode=K3
Title=Toilet Bezoek
TextBeforeValue="Aantal Bezoeken : "
TextAfterValue=Toilet
Units=
BackGroundColor="#5E697A"
SampleSize=200
Height=30
HeightSpacer=8
ToolTips=1
Offset=0
ShowCurrentValue=1
ShowLowHighValues=2
Data=$DS:_17
DelayCount=1
DivideValue=1
*** read values only ***
CurrentValue=17
HighValue=17
LowValue=17
Counter=
Have i made a mistake somewhere???
ed
The value 17 means that the device status is unknown and really means it has not been set by the script/plugin/homeseer.
I'm not sure what you are trying to achieve on the graph? The number of flushes a day and when they happened?
If so, it would be easier to write a small script that would produce a staircase graph, i.e it steps up each time you flush.
You need a simple counting script. Call it flushcount.vb
Get your DS10 to trigger this script without any optional parameters.
Create a new virtual device and set the housecode below to suit.
PHP Code:Sub Main(ByVal Reset As String)
Dim lvalue As String
Dim ltotal As String
Dim Housecode As String = "A25"
If Len(Reset)>0 then hs.SetDevicevalue (Housecode, -1)
If hs.DeviceString(Housecode) = "" Then hs.SetDevicevalue (Housecode, -1)
lvalue= hs.Devicevalue (Housecode)
ltotal = lvalue +1
hs.SetDeviceString (Housecode, "<img src='\images\toilet.gif' >" & " Flushes Today: " & Cstr(ltotal), true )
hs.setdevicevalue (Housecode,ltotal)
end sub
To reset the script, create an event to run at midnight but call the script with optional parameters:
("Main","1")
This will reset the counter back to 0
Use the devicevalue for this device in my graph and it will step up after each flush and then drop again at midnight.
Jon,
How many "points" does this graph? That is, if I wanted the graph to show 24 hours, how often do I need to update the graph in order to get enough points to do a rolling 24 hours?
--DanTasker, to a person who does Homeautomation...is like walking up to a Crack Treatment facility with a truck full of 3lb bags of crack. Then for each person that walks in and out smack them in the face with an open bag.
