The minimum is always set to 0 unless you set the offset. If you read minus values, you set the offset which becomes the new minimum i.e. with an offset of 20, the baseline is actually -20
Jon00 Virtual device graphing utility
OK, then in many cases having the max would work. There would still be cases where I would want to specify a min (positive) and max, for example indoor temps where I would like them to all have a min of say 65 and a max of 85. This allows the graph to show much more granularity. Not sure if both a min and max are feasible though!
Originally posted by jon00 View PostThe minimum is always set to 0 unless you set the offset. If you read minus values, you set the offset which becomes the new minimum i.e. with an offset of 20, the baseline is actually -20
Hi Jon,
I tried to download the new version of the charting utility, and got this error on your site :
Compiler Error Message: BC30648: String constants must end with a double quote.
Source Error:
Line 392:Author="jon00"
Line 393:Filesize="1.53M"
Line 394:Version="1.01
Line 395:Added="01-Apr-2009"
Line 396:Updated="11-Nov-2009"
Source File: D:\Program Files\HomeSeer 2\html\HS2_Downloads.aspx Line: 394Visit zee e-maison : http://www.e-maison.com
Jon,
Thanks very much for the additional functionality!
My inititial testing showed a couple of "Be aware that" items that I wanted to share:
1. Setting the optional MarkerSetpoint will override the MarkerHeight setting.
As originally stated when I requested this functionality, I am using to "mark" a zero line on a rate of change graph, and a 70 degree line on normal temperature graphs. I could see using it to show a 10 mph line for wind, or a freezing line on a temperature graph, etc.
2. Setting the optional MinValue to a negative value works fine, BUT if you then set the Offset value to something OTHER than the absolute value of MinValue, you will get unpredictable results. i.e. If MinValue=-10, the Offset should be set to 10.
I was trying to figure out the exact consequences under various non-conforming conditions to see if there was a useful possibility for setting different values, but could not seem to get a predictable pattern.
Very cool! and thanks again.
Hi all,
Congrats Jon on a great script. I have set it up for two devices and 1 works and the other doesn't.
Graph 1 does not work, it gives a continous 0 value, there is no error message in the log and when I give it a direct value via the script parameter ("Main", "1,10") it reads this value Ok.
Graph 2 works ok.
Is it related to the device value house code of '34. The " ' " is the house code assigned to it by RFXCOM and I cannot change it.
Any ideas
Reg
Liam K
Ini file settings below
[Settings]
ErrorLogging=1
[Graph1]
Housecode=z80
Title=Total Current
TextBeforeValue="Current: "
TextAfterValue=
Units=A
BackGroundColor="#5E697A"
SampleSize=200
Height=30
HeightSpacer=8
ToolTips=1
Offset=0
MaxValue=50
MinValue=0
Data= $DV:'34
ShowCurrentValue=1
ShowLowHighValues=2
DelayCount=1
DivideValue=1
Markerheight=30
MarkerSetpoint=
MarkerDuration=0
MarkerType=1
*** read values only ***
CurrentValue=0
HighValue=0
LowValue=0
Counter=
[Graph2]
Housecode=z81
Title=Line Voltage
TextBeforeValue=
TextAfterValue=
Units=V
SampleSize=200
Height=30
HeightSpacer=8
ToolTips=1
Offset=0
MaxValue=
MinValue=
Data=$DV:r23
ShowCurrentValue=1
ShowLowHighValues=2
DelayCount=1
DivideValue=1
Markerheight=30
MarkerSetpoint=
MarkerDuration=0
MarkerType=1
CurrentValue=230
HighValue=230
LowValue=228
Counter=
[blank]
Housecode=
Title=
TextBeforeValue=
TextAfterValue=
Units=
SampleSize=200
Height=30
HeightSpacer=8
ToolTips=1
Offset=0
MaxValue=
MinValue=
Data=
ShowCurrentValue=1
ShowLowHighValues=2
DelayCount=1
DivideValue=1
Markerheight=30
MarkerSetpoint=
MarkerDuration=0
MarkerType=1
CurrentValue=
HighValue=
LowValue=
Counter=
You can use the following in the ini to display a range of pastel colours (from blue, through green, orange & red) for temperature
-58 to +212 for fahrenheit use
Range1Upper=14
Range1Lower=-58
Range2Upper=23
Range2Lower=14
Range3Upper=25
Range3Lower=23
Range4Upper=32
Range4Lower=25
Range5Upper=41
Range5Lower=32
Range6Upper=50
Range6Lower=41
Range7Upper=54
Range7Lower=50
Range8Upper=59
Range8Lower=54
Range9Upper=68
Range9Lower=59
Range10Upper=77
Range10Lower=68
Range11Upper=86
Range11Lower=77
Range12Upper=95
Range12Lower=86
Range13Upper=122
Range13Lower=95
Range14Upper=212
Range14Lower=122
You can use the following in the ini to display a range of colours (from blue, through green, orange & red) for temperature
-50 to +100 for celcius use
Range1Upper=-10
Range1Lower=-50
Range2Upper=-5
Range2Lower=-10
Range3Upper=-2
Range3Lower=-5
Range4Upper=0
Range4Lower=-2
Range5Upper=5
Range5Lower=0
Range6Upper=10
Range6Lower=5
Range7Upper=12
Range7Lower=10
Range8Upper=15
Range8Lower=12
Range9Upper=20
Range9Lower=15
Range10Upper=25
Range10Lower=20
Range11Upper=30
Range11Lower=25
Range12Upper=35
Range12Lower=30
Range13Upper=50
Range13Lower=35
Range14Upper=100
Range14Lower=50
[Language]
Phrase1=""
Phrase2=""
[Info]
Version=V1.05
The first point is already in the instructions (under the Markerheight entry) but is easily missed.
With regards to the second, the offset can be equal or larger than the minvalue setting.
So with your example of -10 the offset could be 10, or 20 or 30 etc.
Graph 2 works ok.
Any ideas
Reg
Liam K
Setting the devicevalue would be for the plugin author to do. The problem is that devicevalues are integer based (whole numbers) so with your readings it would only save 8 not 8.6. This issue is normally handled by the script/plugin author, multiplying readings by 10 or 100. The graphing has an option to bring this back to the correct reading by dividing by 10 or 100 etc.
Is this reading stored anywhere else such as an ini file?
Doesn't work for housecode '
Originally posted by jon00 View PostThanks!
Obviously if you use devicevaluebyname then you would need to do as you suggested but surely it is much easier to just use the device value of the house code?
i.e. if Garage Freezer Temperature had a house code of t78
Within the INI file for that Graph, you would use:
Data=$DV:t78
As for the location value, yes it can be changed to anything you wish.
If I do: Data=$DV:'8
It doesn't work.
But, it seems to be a Homeseer Bug.
In a script that I just threw together,
hs.devicevalue("'8") returns 0
hs.devicevaluebyname("Outside Outside Temperature") returns the correct value!
I've put in a bug report, but am not hopeful... Good luck getting HST to fix this. They're too focused on ZWave.
