I wanted to poll the community and see how you monitor and control garage doors with Homeseer. My set up:
* Homeseer 2.3.0.60 using Mark's 1.4 Insteon plugin, PLM
* I/O Linc 2450 connected and setup as recommended by Smarthome in the garage door kit
* Three clean up events that as changes are seen to the "Garage Door" device, it will change the string to "open" or "closed" and email if it is left open for 10 mins.
The problem I am having is that sometimes, Homeseer and/or KeypadLinc button doesn't see an "open" or "closed". I would like to poll the 2450 for the status of the garage door sensor but since the 2450 is in momentary C mode, it will always come back as "off" regardless of the garage door status. It sounds like I may have some noise on my network but I thought Insteon overcomes that by design.
Although notifications wouldn't work like I want, I thought band-aid would just to automatically send an "off" after 10 mins and have the 2450 figure out if it is closed or not (as designed) and close it if necessary. The KeypadLinc sends an on and off and the 2450 responds appropriately but the odd thing is that the 2450 will only respond from Homeseer if I send an "on"... and "off" doesn't do anything. "On" will open it if closed and close it if open. The KeypadLinc "on" will only open it if it is closed and visa versa (as designed).
How is everyone else doing this? Anyone seeing this behavior? Any comments would be appreciated.
