Yep, it moved and selected an icon when I changed the command to 2 clicks - weird
Jon00 Remote Computer Control & Network Monitor (HS2, HS3 & HS4)
Originally posted by JimBob View PostI'll have more of an experiment tonight seeing what other commands I can use. If I suspend though, not sure how I will wake it again remotely.
Wake On LAN.Originally posted by rpradeThere is no rhyme or reason to the anarchy a defective Z-Wave device can cause
Originally posted by JimBob View Postmmm, it's a wireless tablet. I'll have a look for options in BIOS but I don't hope out much hope it supports WoWLAN.
Thanks.
Ahhh yes. Good point. As far as WOL goes you're probably hosed.Originally posted by rpradeThere is no rhyme or reason to the anarchy a defective Z-Wave device can cause
I tried the ssaveron/ssaveroff command on a client running on a desktop PC with Win 8.1 and it behaves the same way as the tablet. That is, the screen saver is never turned off. So at least it seems to be particular to Win 8.1.
Jon, what mechanism do you use for accessing the screensaver by the client? I can have a look around for differences with windows 8.1
I have been doing a lot of experimenting, and stumbled on Autohotkeys utility. This is quite powerful and provides a scripting facility which allows you to send wm_syscommand messages to the windows api. I got to the point where I thought I had cracked it, allowing me to disable the screensaver. But whatever way I configure to run it, either by a hotkey or a precompiled script, when I try to execute it via the Jon00client it doesn't get executed when the screensaver is active. This does seem specific to Windows 8, with it's screensaver behaving differently to previous versions of windows. Close but a dead end now.
So the next best solution I found it to use the 'changebrightness' option within nircmd. The screen can be dimmed to almost completely dark and brightened to full brightness by using the Jon00client 'run' command. So I am happy with this now. Thanks for the help.
Just a small update on my disappearing voip box issue. I pinged the device from my desktop using ping -t and let it run for something like 10 minutes and it didn't take the box offline. So it's gotta be something else. Sorry if I'm beating a dead horse here but I just want to be clear. All the network intrusion script does is ping?Originally posted by rpradeThere is no rhyme or reason to the anarchy a defective Z-Wave device can cause
Originally posted by jon00 View PostYes, nothing less....nothing more.Originally posted by rpradeThere is no rhyme or reason to the anarchy a defective Z-Wave device can cause
Originally posted by jon00 View PostWhat version of HS3 are you running?
HS3 Pro Edition 3.0.0.187 (Windows)
