are you seeing the x10 interface initialized in the hs log when hs starts up
Insteon PLM Plug-In Version 1.5.3 (license required)
Mark
HS3 Pro 4.2.19.5
Mark
Yes, the X10 appears to be loading.
<TABLE border=0 cellSpacing=2 cellPadding=0 width="100%"><TBODY><TR><TD class=LOGDateTime0 noWrap align=left>3/18/2011 6:22:31 AM </TD><TD class=LOGType0 colSpan=3 align=left>Plug-In </TD><TD class=LOGEntry0 colSpan=8 align=left>Finished initializing plug-in Insteon</TD></TR><TR><TD class=LOGDateTime1 noWrap align=left>3/18/2011 6:22:31 AM </TD><TD class=LOGType1 colSpan=3 align=left>Plug-In </TD><TD class=LOGEntry1 colSpan=8 align=left>Initializing X10 Plug-in: Insteon On COM Port 14</TD></TR><TR><TD class=LOGDateTime0 noWrap align=left>3/18/2011 6:22:31 AM </TD><TD class=LOGType0 colSpan=3 align=left>Plug-In </TD><TD class=LOGEntry0 colSpan=8 align=left>Initializing Plug-in: Insteon</TD></TR><TR><TD class=LOGDateTime1 noWrap align=left>3/18/2011 6:22:31 AM </TD><TD class=LOGType1 colSpan=3 align=left>Plug-In </TD><TD class=LOGEntry1 colSpan=8 align=left>Finished initializing X10 interface Insteon</TD></TR></TBODY></TABLE>
KeithH
Keith, can you rollback to the previous plugin ver you had installed and see if x10 works again
i know i had some x10 changes in 1.5.3 so maybe i broke somethingMark
HS3 Pro 4.2.19.5
Mark
I rolled back to the older revison and it still didn't work, so I started looking elsewhere. The FilterLinc 1626-10 was removed that was recently added to help with the PLM dropouts and it cleared the problem. Very odd, it worked for a few days and about the time I upgraded to 1.5.3, the problems started. If I get a chance, I will sweep it with a specturm analyzer and see what gives. Sorry for goose chase, seen any of these go bad?
KeithH
KeithH
so what is the working combination now? v1.5.3 and no filterlincMark
HS3 Pro 4.2.19.5
Originally posted by gjtherk@comcast.net View PostHow, or where is the Interface Crashes trigger?Mark
HS3 Pro 4.2.19.5
Originally posted by gjtherk@comcast.net View PostThank you. Upgraded to 1.5.3. yesterday. Seemed fine until I got home today and the system had locked up. Rebooted and working fine now.Mark
HS3 Pro 4.2.19.5
Lockup
Came home to a lot of lights on that should have been off. Looked at HomeSeer and everything that had attempted to run was a black button that says something to indicate unknown.
I updated the driver for port 6 (HomeSeer) and since then no connection to HomeSeer whatsoever. The port no longer exists.
Tried other ports - no luck.
Originally posted by gjtherk@comcast.net View PostCame home to a lot of lights on that should have been off. Looked at HomeSeer and everything that had attempted to run was a black button that says something to indicate unknown.
maybe its time to run ftclean.exe utility from the ftdi chipset site. check it out.Mark
HS3 Pro 4.2.19.5
did you try unplugging the usb cable from the computer and reconnecting. also a reboot might helpMark
HS3 Pro 4.2.19.5
Update
Disconnected USB cable, rebooted, Com port 6 still MIA but it looks like the system is coming up on port 7. Interestingly, USB Serial Port (COM7) is FTDI 2.8.2 which i don't believe it was before.
I am able to control things from the computer. Log only shows one line - last event.
Still checking things out.
Progress. At least I have the Insteon Configuration button showing.
