Several weeks ago I updated to the latest-n-greatest Insteon Plug-in. Since then, I've seen three recurring issues.
1) None of my Insteon Triggers work (two each 2450 on/off triggers).
2) I have a 1-minute recurring script which checks the status of my garage doors and either turns on or off a light. Several times each day (3-10...haven't counted) the light will turn on for a minute then back off. The door has been closed for hours when this happens.
3) The biggest annoyance is that I now periodically (3-4 times/week) get an HS error about a long-running script. My only recourse is to shut down and restart HS. I only have a minimal number of scripts; the aforementioned garage door monitor and one which checks DeviceLastChange time of a few motion sensors to decide if my dogs are home. None of which should run more than 1 second at most. Of course, the error message doesn't say which script is running. I attribute this to the plug-in as it only started after I upgraded my plug-in.
Does any of this sound familiar? Any thoughts?
