Sorry Moskus. I tried for another 2 hours (I had tried all this before BTW) but HS refuses to accept the same POST string with Credentials when local login is enabled.
Jon00 Homeseer Plugin Enable/Disable utility
I don't know. I downloaded the plugin and tried it here....works fine:
Code:Aug-27 16:10:25 Info Plugin ThinkingCleaner with instance: has disconnected Aug-27 16:10:25 Plug-In Shutting down Plug-In: ThinkingCleaner Aug-27 16:10:25 Event Running script in background: C:/Program Files (x86)/HomeSeer HS3/scripts/Jon00PluginSet.vben("Main","ThinkingCleaner;0") Aug-27 16:10:25 Event Event Trigger "Test PluginSet" Aug-27 16:10:25 Event Event Test PluginSet triggered by the event page 'Run' button. Aug-27 16:09:50 Plug-In Finished initializing plug-in ThinkingCleaner Aug-27 16:09:50 ThinkingCleaner DEBUG1: GetLogLevel: Entered function Aug-27 16:09:49 Info Plugin ThinkingCleaner has connected. IP:127.0.0.1:2529 Aug-27 16:09:49 Event Running script in background: C:/Program Files (x86)/HomeSeer HS3/scripts/Jon00PluginSet.vben("Main","ThinkingCleaner;1")
camerun
Multiple Instances of Plugin
Jon,
Thanks for the great work. I have noticed that if you have multiple instances of a plugin and you try to disable/enable a plugin after the multiple instance plugin, it will disable the wrong one. For example, I use a DirecTv plugin and it has two instances running, one for each room. The script will disable/enable the plugin before the plugin I am trying to control. If I delete the multiple instance, it works as planned. Any thoughts?
camerun
Ok,
Thanks for looking into it. I see your point about counting the list, not the most convenient if you add/delete plugins. Right now I am just using the name below the one I need to disable/enable and it works.
