Originally posted by rprade
View Post
HomeSeer SmartHome Skill (Alexa Version 3 API)
Originally posted by ldplusse View PostCould you please create a real documentation page. with detailed explanations.
The link that is referred in the top is not a documentation.
I have read ALOT on the forum and see many people are confused about what to call their devices (My self included).
When i location 1 and 2 used.
Just a quick example.
I only use location 1.
I have a light called 'table light' and this has location 1 as 'Bedroom'
Then is should be able to turn this on by saying 'Alexa, turn on bedroom table light'. But that device is not found.
I have to rename my light to 'Bedroom Table Light' and still have location 1 as 'Bedroom'.
The problem with this is, i cannot 'lock' a Echo Dot, to the bedroom and when talking to the bedroom echo, just say 'Alexa, turn on table light'.
Why shall i tell the name of the room if Alexa is in the bedroom. I have table lights in almost every room.
I know that Alexa in a group can turn on all lights in that group, by saying 'Alexa, turn on lights'. But i dont want that.
i also dont know how to turn a Hue light red or any color, because there is no documentation about what the phrases is for that.
Do i make sence.
i have just started with Alexa and love the idea of her controlling stuff.
What you should be able to do is create a bedrom group with your table light and the bedroom dot called bedroom - and say turn on the bedroom lights from any device or lights on from your bedroom.
Originally posted by rprade View PostSame here. I have only the V3 skill enabled and linked. MyHS is connected to my system. I only have a handful of devices voice enabled, the same devices that were working under V2. They are set for all users and have the proper control use set. 3 dimmers, 2 switches, 2 thermostats and 2 locks. I deleted all of the devices under V2, before enabling V3. None of the devices are discovered either manually or automatically over 2 days.
email set to support.HS4Pro on a Raspberry Pi4
HSTouch Clients: 1 Android
We are seeing an issue with the Nest thermostat, do you have one of those installed?
Originally posted by rjh View PostWe are seeing an issue with the Nest thermostat, do you have one of those installed?
The only reason I have enabled a very small subset of devices is for testing purposes. Obviously unless/until they are discovered I cannot start configuring rooms or groups. My initial testing with V2 resulted in detected and controllable devices, but it was too limited.
This is not a technology we are reliant on, so I can test whatever is needed.HS4 Pro, 4.2.19.0 Windows 10 pro, Supermicro LP Xeon
It still isn't clear to me if this will work with .318. When I tried it last evening, I too did not see any discovered devices. I saw some which were offline.
Can someone add to this?
RobertHS3PRO 3.0.0.500 as a Fire Daemon service, Windows 2016 Server Std Intel Core i5 PC HTPC Slim SFF 4GB, 120GB SSD drive, WLG800, RFXCom, TI103,NetCam, UltraNetcam3, BLBackup, CurrentCost 3P Rain8Net, MCsSprinker, HSTouch, Ademco Security plugin/AD2USB, JowiHue, various Oregon Scientific temp/humidity sensors, Z-Net, Zsmoke, Aeron Labs micro switches, Amazon Echo Dots, WS+, WD+ ... on and on.
Originally posted by langenet View PostIt still isn't clear to me if this will work with .318. When I tried it last evening, I too did not see any discovered devices. I saw some which were offline.
Robert
The new version 3 API adds some new features. To take advantage of all of the new features, HS3 version 3.0.0.398 or later is required.
Looks like it won't work with .318
Can you email me your HS hsd data file, we can then load it and see which device is causing the issue.
Originally posted by rprade View PostNo, the thermostats are Go Control Z-Wave. I have 8, but only 2 are configured for voice control. The enabled switches and dimmers are HomeSeer, one device is virtual (on-off) and the locks are Schlage. The only other skill I have enabled is Sonos, which is working.
Just a heads up...
I did not have any devices imported. So all of this worked the first time. I did not check how many devices I had set to "Enable Voice Command", so it important more than I really wanted.
I would suggest that you start with a small set of devices to import to Alexa (selecting in HomeSeer to "Enable Voice Command". It really is a pain per Amazon's design to remove unwanted devices.
You will need to manually select each device singularly and send it to the trash to delete.
Argh!HomeSeer 2, HomeSeer 3, Allonis myServer, Amazon Alexa Dots, ELK M1G, ISY 994i, HomeKit, BlueIris, and 6 "4k" Cameras using NVR, and integration between all of these systems. Home Automation since 1980.
I also dont discover devices with the new skill ,
I am on 398, devices are discovered with the old skill without issues.
BartRegards Bart
Win7 64Bit on Intel NUCI7 with SSD
HSPRO 3.
Devices; 1370 Events; 691
Jon00 Scripts, JowHue, HSTouch, Plugwise, Z-wave, Ultranetatmo, Ultracam, PHlocation, BLUSBUIRT, MeiHarmony, Buienradar, MEiUnifi Pushover 3P, Random, Nest HSPhone and Blueiris
Visonic Powermax Alarm System (HS3) Interface: http://www.domoticaforum.eu/viewtopic.php?f=68&t=11129
Originally posted by rjh View PostNote that the new skill is server based, so you won't see the discovery message in the HS log. Make sure the original skill is disabled. If no devices are found, send a message to support@homeseer.com with your MyHS login ID so we can investigate.
I'm not sure what is up as whilst the devices are there now they are quite delayed (couple of seconds) and they also frequently say on the top 'Server is unresponsive'. I've noticed that the status of these devices is not reflected on the app if the status of a device in HS changes however don't know if that is by design or not.
We are adding some fixes on the server, so yes, at some point if we fix your issue, your devices will just show up. Amazon runs a discover about once an hour on every system.
Originally posted by mrhappy View PostDone thanks however I just checked (after I sent the email! #16583) and it looks as if the devices have been discovered at some point during the day.
