Hi all,
Trying to use BLLock to add user PINs. Instead, in the log, I'm getting this:
theResponse --> { "Response":"Error, missing interface" }
Here's the full section of the detailed log -- and I do have a non-standard port for HS3:
Does anyone know what "Error, missing interface" means? I do have JSON enabled and when I do test posts to /JSON, I do get responses.
HS3 3.0.0.423
ZWave: 3.0.1.206
03/17/2018 01:43:41:922 PM : v3.0.11.0 - Send_Homeseer_JSON_Request(): port --> 81 03/17/2018 01:43:41:922 PM : v3.0.11.0 - Send_Homeseer_JSON_Request(): fullLanIp --> 192.168.0.84 (KCX-HS) 03/17/2018 01:43:41:922 PM : v3.0.11.0 - Send_Homeseer_JSON_Request(): splitArray.Length --> 2 03/17/2018 01:43:41:922 PM : v3.0.11.0 - Send_Homeseer_JSON_Request(): lanIpAddress --> 192.168.0.84 03/17/2018 01:43:41:922 PM : v3.0.11.0 - Send_Homeseer_JSON_Request(): url --> http://192.168.0.84:81/JSON 03/17/2018 01:43:41:922 PM : v3.0.11.0 - Send_Homeseer_JSON_Request(): parm: request; value: pluginfunction 03/17/2018 01:43:41:922 PM : v3.0.11.0 - Send_Homeseer_JSON_Request(): parm: plugin; value: Z-Wave 03/17/2018 01:43:41:922 PM : v3.0.11.0 - Send_Homeseer_JSON_Request(): parm: function; value: AddUserCodePin 03/17/2018 01:43:41:922 PM : v3.0.11.0 - Send_Homeseer_JSON_Request(): parm: p1; value: 03/17/2018 01:43:41:922 PM : v3.0.11.0 - Send_Homeseer_JSON_Request(): parm: p2; value: 5 03/17/2018 01:43:41:922 PM : v3.0.11.0 - Send_Homeseer_JSON_Request(): parm: p3; value: 1111 03/17/2018 01:43:41:922 PM : v3.0.11.0 - Send_Homeseer_JSON_Request(): parm: p4; value: Test user 03/17/2018 01:43:41:922 PM : v3.0.11.0 - Send_Homeseer_JSON_Request(): parm: p5; value: 03/17/2018 01:43:41:922 PM : v3.0.11.0 - Send_Homeseer_JSON_Request(): parameters set 03/17/2018 01:43:41:922 PM : v3.0.11.0 - Send_Homeseer_JSON_Request(): theResponse --> { "Response":"Error, missing interface" } 03/17/2018 01:43:41:922 PM : v3.0.11.0 - Send_Homeseer_JSON_Request() finished 03/17/2018 01:43:41:922 PM : v3.0.11.0 - Request_Add_User_Code_Pin(): theResponse --> { "Response":"Error, missing interface" } 03/17/2018 01:43:41:922 PM : v3.0.11.0 - Request_Add_User_Code_Pin(): theJsonResponse.ToString --> JSONResponseZWaveAddUserCodePin: -------------------------------- Response: Error, missing interface 03/17/2018 01:43:41:922 PM : v3.0.11.0 - Request_Add_User_Code_Pin() finished
HS3 3.0.0.423
ZWave: 3.0.1.206
