CPU usage
    CPU usage
    Hey:
    I just noticed my CPU on my Windows instance is pretty much pegged.
    I looked at the processes and the culprit is HSPI_ZWAVE.exe.
    I am running the Zwave plugin 3.0.1.190. I have two ZNETS: one is on a VPN. I tried disabling that and did not have any luck.
    I turned the plugin off: and then reenabled it and it is back to zero.
    Am I alone on this?
    HS3 Pro Edition 3.0.0.435 (Windows Server 8.1 on ESXi box)
    Plug-Ins Enabled:
    Z-Wave:,RaspberryIO:,AirplaySpeak:,Ecobee:,
    weatherXML:,JowiHue:,APCUPSD:,PHLocation:,Chromecast:,EasyTr igger:
    Originally posted by wpiman View Post
    Hey:
    Am I alone on this?
    No, this is a common issue with the Z-Wave plugin. I have been able to repeat the issue when ever I add a ZWave node to the system. Usually when using the z-tool app but I have seen reports that even using the web UI will cause the same issue. Only resolution is to disable an enable the plugin.
    HS3 3.0.0.423 & HSTouch 3.0.55 with 700 Devices, 358 Events
    Plugin's:
    BLBackup, BLOccupied, BLShutdown, EasyTrigger, Ecobee,
    weatherXML, Jon00 Alexa Helper, Network Monitor, Z-Wave 3.0.1.206
    HS4 4.2.6.0 &HSTouch Designer 3.0.80
    Plugin's:
    BLBackup, BLOccupied, BLShutdown, EasyTrigger, Ecobee, Nest, AK Bond
    weatherXML, Jon00 Alexa Helper, Network Monitor, MyQ, Z-Wave
      I might have seen this with a much older Z-wave plugin. I only have one Z-net and I run 3.0.1.190 of the PI on HS3 Pro Edition 3.0.0.435 (Windows Server 2016) and I have never seen this. So I wonder if it has to do with have two Z-Nets.
      Have you tried to disable on (not even sure if this is possible) to see how the system behaves? If having two Z-Nets manifests this problem, it might be worth bringing this up with HS support.
      Robert
        I too have seen this on occasion. Restarting has fixed it in the past.
        I use a single smart-stick.
          Next time it happens, try opening the Controller Management page (Plugins->Z-Wave->Controller Management) and see if it drops off.
          I wrote a script to automate the backup of the controllers. At some point, I realized that 10-30 minutes after running, the Z-Wave plugin CPU would peg. Found that simply visiting that page would make it stop. I modified the script slightly (to leave the page in a different state) and it hasn't happened since. Very weird...
            ZWOLFPACK: I would have gone to that page to disable and enable my ZNETS.
            There is no way to disable and reenble a plugin from an event, is there?
            Plug-Ins Enabled:
              Jon00 publishes a utility to do that. Check his site, there is a support thread on this forum for it as well.
              Sent from my Pixel 2 using Tapatalk
                I have not tried any of his stuff, but this seems to fit the bill:
                https://forums.homeseer.com/showthread.php?t=150325
                  Then you are missing out on some of the best Homeseer utilities available!
                    Agreed. Jon00's stuff is top notch and well worth a donation. His scripts and utilities greatly enhance HS.
                      They are great, but too easily over looked because they are not advertised in the updater.
                      I think keeping track of them, installing and updating them is kind of a pain when compared.
                      Joe (zimmer62)
                      BLSecurtiy, AC-RF2, RCS Serial Thermostats, RFXCOM SMarthome SwitchLinc, mcsXap, Global Cache GC100, SqueezeBox, TWA_ONKYOINTEGRA, BLLogMonitor, BLPlugins, BLRadar, BLSpeech, BLZLog.aspx, HSTouch (Windows, iPhone, iPod), USB Mimo touchscreens, VMWare Server, Vortexbox, Windows Home Server, MyMovies, Windows Media Center, X10, ZWave, and much much much more.
