Line in on Boom
    Line in on Boom
    There is not plugin function for this, though you can use the plugin PlayerSendCLICommand command in HS3 (see plugin doc) to send the Squeezebox CLI command for the Boom if any to switch the input line (not sure what that CLI command is)
      As an FYI, you need to enable the Line In plugin in LMS for the Boom to have the ability to control it. Supposedly the cli command to turn it on is
      00:04:20:xx:yy:zz setlinein linein
      but I haven't tried this myself and I don't know what the command is to turn it off. It may automatically turn off if you start playing a regular source.
      Cheers
      Al
        The script would be something line though have not tested it. playerInstance needs to be the instance of the Boom player. You can find the instance in the SqueezeBox > Status page.
        PHP Code:
        Sub Main(Parm As Object)
          Try
        Dim playerInstance As String "Player_0015833d0a57"
        Dim Args(1) As Object
            Args
        (0) = "setlinein linein"
        Args(1) = False
            hs
        .PluginFunction("SqueezeBox"playerInstance"PlayerSendCLICommand"Args)
          Catch
        ex As Exception
            hs
        .WriteLog("SqueezeBox Scripts""Exception " ex.ToString)
        End Try
        End Sub
          Thank you, the script worked.
