Has anyone experienced this? When I run HS 2 (1951) as an application, the MR26A2 plugin starts up ok and reads X10 signals ok.
When HS is run as a service the following error message is received:
08/08/2005 19:10:06 ~!~Info~!~Initializing Plug-in: MR26A RF Receiver ver 2
08/08/2005 19:10:06 ~!~startup~!~Single port MR26A Interface version 2.0.4 starting
08/08/2005 19:10:06 ~!~COM Plugin~!~Calling InitIO
08/08/2005 19:10:06 ~!~startup~!~MR26A Communications Module version 2.0.4 starting
08/08/2005 19:10:06 ~!~startup~!~MR26A Communications Module startup FAILED
08/08/2005 19:10:06 ~!~Error~!~No port selected for MR26A interface
08/08/2005 19:10:06 ~!~Info~!~Done initializing plug-in MR26A RF Receiver ver 2
I cannot see anywhere in the setup where the port is defined. When HS runs as an app, it correctly opens up COM1 and communicates ok.
Any takers? Or should I raise a ticket.
