Originally posted by S-F
View Post
HS3 is way above vera, that it shouldn't even be considered in the same ballpark. I remember when I first moved, I was way overwhelmed and had to change my way of thinking because the two event engines (AKA PLEG) work completely differently. Once you get over that, you will find HS3 blows Vera outta the water. Anything you can do in Vera, you can do in HS3, only better and easier... and also most importantly... reliably.
If you have your zwave network on vera still, you have cut your legs off. That part HS3 shines the most at I think. The event engine is the best I have seen with any product and I vetted a few before making the switch.
The one and ONLY thing that I have seen that PLEG has over HS3 is sequential triggers. This to me is a nice to have, but also minor.
Do yourself a favor and toss that POS. The horror it caused me was so bad, I have blocked it from my memory.
