Schlage lock won't enroll - Solved!
    I am using a Aeolab Zstick 5 which seems to enroll my schlage (however shlage never shows the checkmark icon which means it enrolled).
    When I go into my HS3 I can see that it was enrolled but with errors:
    Aug-29 9:12:32 PM Z-Wave Warning Failed to retrieve Z-Wave class information for node 21, device synchronization/creation will not continue for this node.
    Aug-29 9:12:32 PM Z-Wave Cannot reach node 21, will not import any information about this node.
    Aug-29 9:12:24 PM Z-Wave Checking if we can reach node 21
    Aug-29 9:12:24 PM Z-Wave Getting class information for node 21...
    Aug-29 9:12:24 PM Z-Wave Device synchronization needs to get Z-Wave class information for one node.
    Aug-29 9:12:24 PM Z-Wave Syncing Z-Wave nodes with device list...
    I then tried to remove the node from my z-wave and it does remove it (schlage even shows the checkmark meaning it was removed).
    But when I try to re-enroll I keep getting the same thing. The zstick seems to have enrolled it but schlage does not show the checkmark icon. And then well I get the error within HS3 as shown above.
    No clue what the issue is...
    More info:
      Now it looks like this but I can't seem to connect to it or get it's status....
        How close is the lock to your interface when you try to control it?
          I was using a laptop with the zstick plugged into it and I was standing right beside the door lock while it was in enrollment mode.
            The thing is I can't really control it afterwards as this is what I see in my GUI:
            There is no ON/OFF or anything and the device is shown as OFF.
              What version of HS3 are you running and what version of the Z-Wave plugin are you running? You may have to do a rescan on the lock and keep it awake while the scan is on going.
                Both are the latest versions. By scan you mean keep it enrolled as is a keep trying to scan? Or remove and re-enroll?
                  Finally solved. This is what I did:
                  Went through the z-wave control management (under plug-in) and did a full scan of existing devices while I kept on re-entering the programming code on the schlage in order to keep it in enrollment mode the whole time (it kept giving me the "X" but I kept doing it). I was standing right beside it the whole time.
                    Just exchange schlage lock
                    Old schlage lock would not pair a new software load (HS3 Pro), spent hours trying various steps.
                    Finally just purchased a new one from local hardware shop.
                    It paired first time.
                    I'll return old one as defective. These locks can be such a waist of time.
