Aeotec Nano Dual Switch - No individual output devices created
Hello,
Yes, I experienced the same issue. I removed the device and upgraded the firmware 1.4 and once enrolled again, the two end points had independent switches.
https://aeotec.freshdesk.com/support...rmware-update-
What method did you use to update the firmware? Using the Aeotec application, or via HS?
Cheers
In this use case, I did it all outside of HS3. Once I fired up the Aeotec firmware, I enrolled the device again, updated the firmware and started HS3 and the imported the Node from the Controller. Which is a secure enrolled device via the Aeotec Gen 5 Zstick.
Thanks again.
