3.0.1.152 Strange behaviour to thermostats
Originally posted by rjh View PostWe do have a Stella, so I will check that one.- scheduler.dll
- hscf.dll
- HomeSeerAPI.dll
- interop.hsrecord2.dll
over my .368 installation
All my TRV's are working again, so is the main thermostat. No other changes on my system.
One thing you might be able to help. My startup now shows this error, no idea what it means, how to fix it, and what issues it could cause... and I will have to run this version until .368 has a fix
10/11/2017 16:03:48 ~!~Error~!~DeSerializing object (byte): Unable to load type Scheduler.Classes.TrigComparer required for deserialization. Source=mscorlib
This error has disappeared after a reboot. It could not load all events, and about 40 events have disappeared. Can I get them back ?Last edited by mikee123; November 10, 2017, 12:07 PM.
Originally posted by rjh View PostI have fixed the thermostat issue. The fix is in Z-Wave plugin 3.0.1.155 which is in the Beta section on the plugins page. The issue is related to thermostats that use Celsius mode and use a different precision from US thermostats.
Nov-10 17:38:11 Z-Wave Warning New Interface: Device (Node 22) woke up, but queued command failed to be sent. Command=Poll Device
The error message you posted is not related to sending a setpoint. Are you setting the setpoint using the web interface? Is HS set to Celsius in Setup?
Originally posted by mikee123 View PostThat was super quick. It has not worked though. I am still getting this error, and the setpoint is not being accepted
In setup temperature scale I have Celcius.
The error comes as to get the setpoint into the StellaZ's, I poll them (via an event) when they wake up when I want to send a setpoint. Usually after the poll it says 'Device (Node 35) woke up and Send Other Data command was successfully sent'
So this error looks as if that somehow has gone wrong. I now have also tried disabling polling completely when sending setpoints. that error does not show up any more, I see this in the log:
'Z-Wave New Interface: Z-Wave Wake-Up 'No More Info' Notification sent to Node 22(Thermostat HVAC Guest Bed TRV root)'
And no setpoint has been accepted. I can tell as the rad does not go on or off, and the StellaZ you can normally hear changing setpoints.
I can also see it on the Secure SRT321 on the display, that the sepoint is not changing as that is displaying the current setpoint.
It looks like HS could not send the setpoint when the thermostat woke up. But checking the code, there has not been any changes related to that since the beginning of the year. The thermostat may be going to sleep before the command is able to be sent. I am not sure why this would just start happening. Maybe your Z-Wave network is very busy?
You can enable debug logging and send me the log file. Did you do this already? Someone said they did, but I did not get it. Make sure you zip up the file and rename the extension to something like .zipp, otherwise it will be blocked.
Originally posted by mikee123 View PostIn setup temperature scale I have Celcius.
I did not send a log file, but I'll send a few setpoint changes and log them with debug logging. If it was my zwave network being busy, why would it work as soon as I switch to .318 ? I have no idea but I changed back and forth with 318 to 368. Always works on 318, never on 368 with everything else exactly the same.
And you are using the same Z-Wave plugin when you switch between 318 and 368? That is really odd as this is a Z-Wave issue, I don't see how the HS version would have any affect.
Originally posted by mikee123 View PostI did not send a log file, but I'll send a few setpoint changes and log them with debug logging. If it was my zwave network being busy, why would it work as soon as I switch to .318 ? I have no idea but I changed back and forth with 318 to 368. Always works on 318, never on 368 with everything else exactly the same.
Yes I have tried with .130, .152 on .318 and .368 and (.155 on .368)
sending the logs now
What is your email pls ?
I have also noticed other problems with Zwave .155, Greenwave power nodes stop energy reporting. Aeotec smart switch Gen 5 includes ok, but cannot get security scheme and only generated 1 child device (on/off) but none for the poweer reportingLast edited by mikee123; November 11, 2017, 11:50 AM.
Originally posted by rjh View PostIt looks like HS could not send the setpoint when the thermostat woke up. But checking the code, there has not been any changes related to that since the beginning of the year. The thermostat may be going to sleep before the command is able to be sent. I am not sure why this would just start happening. Maybe your Z-Wave network is very busy?
Originally posted by rjh View PostTry Z-Wave plugin 3.0.1.156, I backed out a recent change related to wakeup's, see if it helps.
The logs sent to me did not show any errors and the set point command seems to have been sent ok.
