I've been getting a bunch of MQTT errors in my log lately and I'm trying to figure out how to address it. Here's a section from the log:
It seems I always get errors on the diy/esps/espNorthFloods/rgb/status responses. These are supposed to be RGB value triplets in the format "255,255,255". They seem to display fine in the homeseer device view.
The other error is on the diy/esps/espNorthFloods/light/status topic. As you can see I have two devices that report this type (northFloods and southFloods), one gives the error, the other doesn't. The expected payload is either "ON" or "OFF" Again, they both look fine in the homeseer devices list.
So what does it mean that "the received value is invalid"?
PS, if I'm posting in the wrong subforum, please move it. I couldn't find a dedicated place for this plugin.
Nov-07 6:32:48 PM * MQTT Error: Error occured in client_MqttMsgPublishReceived(). The received value is invalid. Value=32,16,0 Nov-07 6:32:48 PM * MQTT Info: Received MQTT topic: diy/esps/espNorthFloods/rgb/status payload: 32,16,0 Nov-07 6:32:48 PM * MQTT Info: Received MQTT topic: diy/esps/espNorthFloods/brightness/status payload: 100 Nov-07 6:32:48 PM * MQTT Error: Error occured in client_MqttMsgPublishReceived(). The received value is invalid. Value=ON Nov-07 6:32:48 PM * MQTT Info: Received MQTT topic: diy/esps/espNorthFloods/light/status payload: ON Nov-07 6:32:48 PM * MQTT Error: Error occured in client_MqttMsgPublishReceived(). The received value is invalid. Value=32,16,0 Nov-07 6:32:48 PM * MQTT Info: Received MQTT topic: diy/esps/espSouthFloods/rgb/status payload: 32,16,0 Nov-07 6:32:48 PM * MQTT Info: Received MQTT topic: diy/esps/espSouthFloods/brightness/status payload: 100 Nov-07 6:32:48 PM * MQTT Info: Received MQTT topic: diy/esps/espSouthFloods/light/status payload: ON Nov-07 6:32:48 PM * MQTT Info: start Nov-07 6:32:48 PM * MQTT Info: Client is not connected to broker (10.10.1.11). Trying to connect
