I configured Windows 10 Task Sheduler to start HS3 at bootup.
In order to bypass the User Account Control screen, I set it to run whether or not the user is logged in. This causes HS3 to run "hidden" so I cannot access the home screen or the startup log.
I'm not sure that has anything to do with the startup error I'm getting in the log, but I included it for background.
HS3 starts and runs fine at Windows startup but I'm getting the following error:
Nov-16 00:02:56 Database Opening (Mode=Read/Write) up HomeSeer Energy database C:\Program Files (x86)\HomeSeer HS3\Data\Energy\Energy.hsd
Nov-16 00:02:56 Speech Listening for remote speaker connections on port 10401 Nov-16 00:02:56 Startup Initializing Speaker Client Interface Nov-16 00:02:56 Startup Start automation engine...
Nov-16 00:02:56 Error ASP.Net page: Could not load file or assembly 'HomeSeerUtil, Version=3.0.0.1, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified.
Nov-16 00:02:55 Error ASP.Net page: Could not load file or assembly 'HomeSeerUtil, Version=3.0.0.1, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified.
Nov-16 00:02:54 Error ASP.Net page: Could not load file or assembly 'HomeSeerUtil, Version=3.0.0.1, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified.
Nov-16 00:02:54 Z-Wave ************************************************************ *******************
Nov-16 00:02:54 Z-Wave STARTUP COMPLETE: All configured interfaces were successfully initialized.
Nov-16 00:02:52 Startup Creating ASP.NET application host...
Nov-16 00:02:52 Web Server Web Server started on port 80
Nov-16 00:02:52 Web Server UPNP Discovery started
Nov-16 00:02:52 Web Server Local IP address (subnet) is: 192.168.0.103 (255.255.255.0)
Nov-16 00:02:51 Z-Wave Z-Net Interface: ............................................................ ..........
Nov-16 00:02:50 Z-Wave Z-Net Interface: .............................. FINISHED ..............................
Nov-16 00:02:50 Z-Wave Z-Net Interface: ............................................................ ..........
I'd like a clean startup with no errors but I don't know what's causing this. I suspect the Task Scheduler startup has something to do with it.
Current Date/Time: 11/16/2017 6:01:53 AM
Operating System: Microsoft Windows 10 Pro - Work Station
System Uptime: 0 Days 5 Hours 59 Minutes 14 Seconds
IP Address: 192.168.0.103
Number of Devices: 120
Number of Events: 67
Available Threads: 1022
Enabled Plug-Ins
2.0.48.0: BLBackup
1.0.3.0: BLShutdown
2.0.70.0: BLStat
0.0.0.34: Pushover 3P
3.0.1.130: Z-Wave
Enabled Plug-Ins
2.0.48.0: BLBackup
1.0.3.0: BLShutdown
2.0.70.0: BLStat
3.0.1.130: Z-Wave
