Woke up this morning and all devices are gone
    Hi All,
    So, I have had homeseer up and running smoothly for months now. Then this AM, woke up and noticed outside lights were still on then under further investigation I see that I have no devices in the system except those that were recreated by Sonos and Hue. My events loaded but when you look at the events the devices all say ref device not found. I have an older back up to restore from but I am wondering the root of the problem before we have it happen again, etc. Here is what I could find in the log. Also, znet looks like all the nodes are still in it. Thoughts of where to go next and what to do.
    Mar-17 4:47:04 AM Startup HomeSeer version is: 3.0.0.368
    Mar-17 4:47:04 AM Load Config Loading TIMERS...
    Mar-17 4:47:04 AM Load Config Loading COUNTERS...
    Mar-17 4:47:04 AM Load Config 105 total events loaded.
    Mar-17 4:47:03 AM Load Config Loading Events...
    Mar-17 4:47:03 AM Load Config Loading Event Groups...
    Mar-17 4:47:03 AM Load Config 0 total devices loaded.
    Mar-17 4:47:03 AM Database Loading Devices...
    Mar-17 4:47:03 AM Warning Configuration database has no devices in it: C:\Program Files (x86)\HomeSeer HS3\Data\HomeSeerData.hsd
    Mar-17 4:46:57 AM Warning Database failed to open, waiting then retrying...attempt to write a readonly database attempt to write a readonly database
    Mar-17 4:46:52 AM Warning Database failed to open, waiting then retrying...attempt to write a readonly database attempt to write a readonly database
    Mar-17 4:46:47 AM Warning Database failed to open, waiting then retrying...attempt to write a readonly database attempt to write a readonly database
    Mar-17 4:46:42 AM Warning Database failed to open, waiting then retrying...attempt to write a readonly database attempt to write a readonly database
    Mar-17 4:46:42 AM Database Opening (Mode=Read Only) up HomeSeer database C:\Program Files (x86)\HomeSeer HS3\Data\HomeSeerData.hsd
    Mar-17 4:46:42 AM Startup Loading configuration file ...
    Mar-17 4:46:42 AM Startup Database SAVE process started.
    Mar-17 4:46:42 AM Startup Local voice recognition class started.
    Mar-17 4:46:42 AM Startup HSPhone external interface class started.
    Mar-17 4:46:42 AM Startup Plug-In Interface class started.
    Mar-17 4:46:42 AM Startup E-Mail RECEIVE class started.
    Mar-17 4:46:42 AM Startup E-Mail SEND class started.
    Mar-17 4:46:42 AM Startup Web server class started.
    Mar-17 4:46:42 AM Startup Application interface class started.
    Mar-17 4:46:42 AM Startup COM port classes started.
    Mar-17 4:46:42 AM Startup Creating Class Objects...
    Mar-17 4:46:42 AM Startup ************************************************************ ********************
    Mar-17 4:46:42 AM Startup HomeSeer version 3.0.0.368 Edition: HS3 Standard Starting Now
    Mar-17 4:46:41 AM Startup Settings Loaded.
    Mar-17 2:59:48 AM PHLocation UPD Timer elapsed
    Moved to help forum -https://forums.homeseer.com/showthread.php?p=1356439#post1356439
