Thanks guys for your help.
At first, finally, I noticed that only relays (Secu16 outputs) has been troubled by the HS 2.3 upgrade. All secu 16 inputs were still OK. Strange ...
As suggested by Jim S., I deleted and recreated for test only one output on a secu16. It solved the problem for this output only (great !!). I opened the MDB file and check the change at the line of this output. The only one change in this file was in the column "misc". The value changed from -32768 to 32768. All the outputs has the same value. I just replaced -32768 to 32768 for all outputs manually into the MDB file ... and now all outputs are working fine !!!
If someone understood what's wrong with it, congratulations !!!! Anyway it works ... but ... next time, I would appreciate an upgrade without any surprises like this ... :-)
Thanks again for your help.
