Have I got a broken z-Net
    Originally posted by zwolfpack View Post
    Thanks, that's it - gpio is in /usr/local/bin rather than /usr/bin. I'll update that.
    Yeah, looks like your shed one doesn't have the fixes.
    I'll do that, but for the record I have had 0 problems with Z-Nets staying up, remaining connected or connecting on startup since we went through the 1.0.17-1.0.21 fiasco. I attribute that to using high quality SD cards as well as the patches. Before changing to Samsung EVO cards, they would occasionally corrupt on a power cycle. Not too often, but maybe 2-3 times over a year.
    The only reason my kitchen Z-Net was replaced is because of a problem in the GPIO card and that problem only surfaced with Z-Wave backup/restore attempts. It would back up fine, but restore would fail 75% of the time. It had a rev D GPIO.
      Scripts updated.
      My production unit is chugging right along, four months & counting!
      pi@Z-Not:~ $ uptime
      19:42:29 up 122 days, 20:44, 1 user, load average: 0.00, 0.00, 0.00
        Are you familiar with PuTTY? That is the easiest way to SSH in from a PC. http://www.putty.org/
        To login, try pi@<znet ip addr> with password raspberry
        Once logged in, download the zipfile from the previous message by pasting this to the command line:
        wget 'https://forums.homeseer.com/attachment.php?attachmentid=65791&d=1515641659' -O znetcare.zip
        unzip to a folder named znetcare:
        unzip znetcare.zip -d znetcare
        change to the folder and run the first script:
        cd znetcare
        ./znet_info.sh
        Then preview the patch commands:
        ./znet_patch.sh
        Ignore this - I'm in!
          OK, here's the results:
          pi@zBrockhill:~/znetcare $ ./znet_info.sh
          Z-Net version 2 revision 1.0.23
          External (UZB) device detected.
          ser2net port 2001 timeout (seconds): 0 - (per rev. 1.0.18 and prior, and 1.0.23) - not recommended (timeout disabled)
          Your installed ser2net contains the patch added in rev. 1.0.21/1.0.22.
          pi@zBrockhill:~/znetcare $ ./znet_patch.sh
          Note: This is a Z-Net v2, firmware revision 1.0.23
          Note: superuser (root) privilege required to install this patch -
          Note: displaying commands that would be run by superuser.
          Note: /etc/ser2net.conf modifications (< old; > new):
          86,87c86,87
          < 2001:raw:0:/dev/ttyACM0:115200 8DATABITS NONE 1STOPBIT -XONXOFF -RTSCTS
          < 2002:raw:0:/dev/ttyUSB0:19200 8DATABITS NONE 1STOPBIT -XONXOFF -RTSCTS
          > 2001:raw:120:/dev/ttyACM0:115200 8DATABITS NONE 1STOPBIT -XONXOFF -RTSCTS
          > 2002:raw:120:/dev/ttyUSB0:19200 8DATABITS NONE 1STOPBIT -XONXOFF -RTSCTS
          89c89
          < #3001:telnet:600:/dev/ttyS1:19200 8DATABITS NONE 1STOPBIT banner
          \ No newline at end of file
          Note: backing up existing /etc/ser2net.conf...
          install -p /etc/ser2net.conf /etc/ser2net.conf-orig
          Note: installing patched /etc/ser2net.conf...
          install -p -t /etc ser2net.conf
          rm -f ser2net.conf
          Note: patched ser2net binary is already installed - no action.
          Does this make sense?
          Scott
            86,87c86,87
            89c89
            rm -f ser2net.conf
            Scott
            Indeed it does. This shows that you have a European version with external UZB controller, and that the communication patch is not enabled.
            The affected file is /etc/ser2net.conf. The lines prefaced with "<" and ">" show existing (<) and to-be-modified (>) entries. The entry used for the zwave communications is the one starting with 2001 (which is a port number).
            will be changed to
            The difference is that the 3rd field (the timeout) is changed from 0 (disabled) to 120 (2 minutes).
            If you run this script prefaced with sudo, the original file will be backed up and the modified file installed.
            sudo ./znet_patch.sh
            Then reboot.
              #21
              Looking good I think. Ran the patch with any problems and the scripts now report
              ser2net port 2001 timeout (seconds): 120 - recommended value
              Note: /etc/ser2net.conf already has recommended settings - no action.
              I presume that's it all done.
              I'll keep an eye on it and let you know how it's working.
              Thank you again for your help - I would have been sending units back as faulty forever without your advice.
              Cheers
              Scott
                #22
                Great, that looks as expected. This should allow it to get reconnected easier.
                  #23
                  Brilliant - thank you again.
                  Scott
                    #24
                    Bad news - this didn't fix the problem.
                    Any other ideas?
                    Scott
                      #25
                      Any other ideas?
                      Scott
                      What does the log show while it's trying to connect?
                        #26
                        Here's some log entries:
                        2018-01-15 09:06:42 Z-Wave Error The plug-in attempted to make zBrockhill a SIS (Static Information Server) and it failed. No further information is available.
                        2018-01-15 09:06:28 Z-Wave Error zBrockhill: The zBrockhill interface did not respond to the request for the HomeID and Node - it may be disconnected or malfunctioning (2).
                        2018-01-15 09:06:21 Z-Wave Error zBrockhill: The zBrockhill interface did not respond to the request for the HomeID and Node - it may be disconnected or malfunctioning (2).
                        2018-01-15 09:06:11 Z-Wave Error zBrockhill: Exception transmitting to IP 192.168.0.150: Unable to write data to the transport connection: An established connection was aborted by the software in your host machine.
                        2018-01-15 09:03:38 Z-Wave Error zBrockhill: The zBrockhill interface did not respond to the request for the controller capabilities - it may be disconnected or malfunctioning (3).
                        Does that mean anything to you?
                        It works after a cold boot
                        Scott
                          #27
                          You say the problem occurs after rebooting HS3. Does it also occur when cycling the Zwave plugin on the Plugins->Manage page?
                          From the log, post everything starting at the line "The Z-Wave Command Execution Thread was Started or Restarted", after the Zwave plugin starts. Below is a good startup.
                          You are still running this on wired Ethernet rather than Wifi, correct?
                          Jan-15 7:50:29 AM	 	Z-Wave	UZB (Z-Not3): ......................................................................
                          Jan-15 7:50:29 AM	 	Z-Wave	UZB (Z-Not3): .............................. FINISHED ..............................
                          Jan-15 7:50:29 AM	 	Z-Wave	UZB (Z-Not3) is the SIS for the network.
                          Jan-15 7:50:29 AM	 	Z-Wave	UZB (Z-Not3) There is a SUC/SIS in the network.
                          Jan-15 7:50:29 AM	 	Z-Wave	UZB (Z-Not3) Controller is static lib.
                          Jan-15 7:50:29 AM	 	Z-Wave	UZB (Z-Not3) Controller chip type is ZW050x.
                          Jan-15 7:50:29 AM	 	Z-Wave	The interface's security support has been set.
                          Jan-15 7:50:29 AM	 	Z-Wave	UZB (Z-Not3): Found 1 Z-Wave nodes in interface node ID 1 (UZB (Z-Not3))
                          Jan-15 7:50:29 AM	 	Z-Wave	UZB (Z-Not3): Z-Wave interface node ID: 1, Home ID: F2954E94
                          Jan-15 7:50:29 AM	 	Z-Wave	UZB (Z-Not3): Z-Wave Serial API version: 5
                          Jan-15 7:50:29 AM	 	Z-Wave	UZB (Z-Not3): Z-Wave services for the SECURITY COMMAND CLASS were successfully started.
                          Jan-15 7:50:29 AM	 	Z-Wave	UZB (Z-Not3): Controller firmware version: 5.5
                          Jan-15 7:50:29 AM	 	Z-Wave	UZB (Z-Not3): Controller Manufacturer: PowerLynx, ID=0x1, Type=0x4
                          Jan-15 7:50:27 AM	 	Z-Wave	UZB (Z-Not3): Getting node information from controller...
                          Jan-15 7:50:27 AM	 	Z-Wave	UZB (Z-Not3): The Z-Wave API Execution Thread was Started or Restarted.
                          Jan-15 7:50:26 AM	 	Z-Wave	UZB (Z-Not3): Z-Wave Ethernet at IP 192.168.1.111, connected to interface ok.
                          Jan-15 7:50:26 AM	 	Z-Wave	UZB (Z-Not3): The Z-Wave Command Execution Thread was Started or Restarted.
                          Jan-15 7:50:26 AM	 	Z-Wave	UZB (Z-Not3): ----------------------------------------------------------------------
                          Jan-15 7:50:26 AM	 	Z-Wave	Initializing Z-Wave interface UZB (Z-Not3) (Ethernet Interface) at 192.168.1.111, port 2002
                          Jan-15 7:50:26 AM	 	Z-Wave	UZB (Z-Not3): ======================================================================
                            #28
                            Yes, cycling the p/i doesn't help. It needs the zNet to be rebooted before it will work. Restarting HS3 also doesn't fix it.
                            I will try to get more logs next time.
                            Yes, it's wired
                            Cheers
                            Scott
                              #29
                              Good. The main reason I asked that is that for testing its much easier/quicker to cycle the plugin vs. restarting HS3 or the PC.
                              I have a test system which is a Rpi and a UZB controller, same as that used on the Euro-znet except US frequency of course. This disconnects/reconnects without issue each time with the same config as you have as far as I can tell. So you may have a hardware issue with your unit after all But post the logs, that may shed some light on where things are breaking down.
                                #30
                                zWolfpack
                                Happened again this morning - stopped HS3, did a backup and restarted. Here's the gisy of the log...
                                Jan-20 12:21:26 Z-Wave Warning Trying to re-connect to Ethernet interface at IP 192.168.0.150...
                                Jan-20 12:21:25 Z-Wave Error zBrockhill: The zBrockhill interface did not respond to the request for the HomeID and Node - it may be disconnected or malfunctioning (2).
                                Jan-20 12:21:06 Z-Wave Error zBrockhill: Error, the Z-Wave API Transmit Queue is not empty after waiting 20 seconds - the interface may be disconnected or not operational (zBrockhill).
                                Jan-20 12:20:06 Z-Wave Error zBrockhill: Error, the Z-Wave API Transmit Queue is not empty after waiting 20 seconds - the interface may be disconnected or not operational (zBrockhill).
                                Jan-20 12:19:22 Z-Wave zBrockhill: Getting node information from controller...
                                Jan-20 12:19:22 Z-Wave zBrockhill: Z-Wave Ethernet at IP 192.168.0.150, connected to interface ok.
                                Jan-20 12:19:17 Z-Wave Warning Trying to re-connect to Ethernet interface at IP 192.168.0.150...
                                Jan-20 12:19:16 Z-Wave Error zBrockhill: The zBrockhill interface did not respond to the request for the HomeID and Node - it may be disconnected or malfunctioning (2).
                                Jan-20 12:19:06 Z-Wave Error zBrockhill: Error, the Z-Wave API Transmit Queue is not empty after waiting 20 seconds - the interface may be disconnected or not operational (zBrockhill).
                                Jan-20 12:18:06 Z-Wave Error zBrockhill: Error, the Z-Wave API Transmit Queue is not empty after waiting 20 seconds - the interface may be disconnected or not operational (zBrockhill).
                                Jan-20 12:17:13 Z-Wave zBrockhill: Getting node information from controller...
                                Jan-20 12:17:12 Z-Wave zBrockhill: Z-Wave Ethernet at IP 192.168.0.150, connected to interface ok.
                                Jan-20 12:17:10 Informational Host B8-27-EB-D4-72-81 changed from 192.168.0.125 to 192.168.0.150
                                Jan-20 12:17:09 Z-Wave ************************************************************ *******************
                                Jan-20 12:17:09 Z-Wave STARTUP COMPLETE: All configured interfaces were successfully initialized.
                                Jan-20 12:17:07 Z-Wave Warning Trying to re-connect to Ethernet interface at IP 192.168.0.150...
                                Jan-20 12:17:06 Z-Wave Error zBrockhill: Error, the Z-Wave API Transmit Queue is not empty after waiting 20 seconds - the interface may be disconnected or not operational (zBrockhill).
                                Jan-20 12:17:06 Z-Wave Error zBrockhill: The zBrockhill interface did not respond to the request for the HomeID and Node - it may be disconnected or malfunctioning (2).
                                Jan-20 12:15:52 Startup Start up complete.
                                Jan-20 12:15:52 Startup HSSentry is disabled in Setup, sentry will not be started.
                                Jan-20 12:15:52 Startup (Startup.vb script) No speaker clients detected, waiting up to 30 seconds for any to connect...
                                Jan-20 12:15:52 Startup (Startup.vb script) Scripting is OK and is now running Startup.vb
                                Jan-20 12:15:52 Startup Starting Event Scheduler...
                                Jan-20 12:15:52 Startup Running the startup script Startup.vb
                                Jan-20 12:15:52 Startup Starting Find service...
                                Jan-20 12:15:51 Startup Updater services starting...
                                Jan-20 12:15:51 Speech Listening for remote speaker connections on port 10401
                                Jan-20 12:15:51 Startup Initializing Speaker Client Interface
                                Jan-20 12:15:51 Startup Start automation engine...
                                Jan-20 12:15:51 email Initializing email, found 1481 messages
                                Jan-20 12:15:51 Z-Wave zBrockhill: Getting node information from controller...
                                Jan-20 12:15:51 Z-Wave zBrockhill: The Z-Wave API Execution Thread was Started or Restarted.
                                Jan-20 12:15:51 email Start checking server for email using POP
                                Jan-20 12:15:51 Startup Creating ASP.NET application host...
                                Jan-20 12:15:51 Startup Initializing email, will check server for new email
                                Jan-20 12:15:51 Web Server Web Server started on port 80
                                Jan-20 12:15:51 Web Server UPNP Discovery started
                                Jan-20 12:15:51 Web Server Local IP address is: 192.168.0.6
                                Jan-20 12:15:51 Z-Wave zBrockhill: Z-Wave Ethernet at IP 192.168.0.150, connected to interface ok.
                                Jan-20 12:15:51 Z-Wave Starting 'Z-Wave Health' Process Starter for (Brockhill)...
                                Jan-20 12:15:51 Z-Wave zBrockhill: The Z-Wave Command Execution Thread was Started or Restarted.
                                Jan-20 12:15:51 Z-Wave zBrockhill: ----------------------------------------------------------------------
                                Jan-20 12:15:51 Z-Wave Initializing Z-Wave interface zBrockhill (HomeSeer Z-NET Ethernet) at 192.168.0.150, port 2001
                                Jan-20 12:15:51 Z-Wave zBrockhill: ============================================================ ==========
                                Jan-20 12:15:51 Startup HStouch server started, waiting for clients to connect.
                                Jan-20 12:15:51 HSTouch Server Server started on port 10200
                                Jan-20 12:15:51 Plug-In Finished initializing plug-in Z-Wave
                                Cheers
                                Scott
